Results 1 to 10 of 28
Thread: DMX, Renard, sACN Tester
    WI
    2,611
    Default DMX, Renard, sACN Tester
    What about a DMX/Renard/sACN (or whatever else) tester? I've been situations where I would rather use a handheld controller instead of booting my laptop or I just want to isolate a problem, this could fill both problems.
    I will try to keep things through hole, but I will likely include the SMT USB parts for those that don't want to buy a prop-plug. Initially I will focus on DMX and sACN support since those are easily testable for me and then widen the data type options to Renard or others.
    This tester will have an LCD with key switches for menu navigation (sorry no touch screen). In a perfect world it would both receive and transmit each of the protocols. I also plan to implement some diagnostics information for each protocol (IE byte space time, MAB time, etc).
    Since this will be my first battery powered project any advice or design ideas are welcomed.
    Oceanside, CA
    2,363
    Default Re: DMX, Renard, sACN Tester
    Subscribed!
    Jun 2009
    Ottawa, Ontario, Canada
    2,845
    In my ever so humble opinion.. select your enclosure now. Design the board to match your enclosure.
    I've got far too many "half done" projects because I could never get them finished enough to release.
    (Plenty of nice boxes, including batter compartments, at mouser and digikey)
    Standard Disclaimers apply:
    WI
    2,611
    I was thinking about something like this, pelican makes a similar version that costs more. If that seems too big I will continue to look for cases.
    Jan 2010
    Pittsbor, NC
    243
    That sounds interesting.
    A feature I'd like to see, if it's early enough to get requests in?
    DMX start address setting, the type where you output a 0-255 level to set the controller address.
    WI
    2,611
    Quote Originally Posted by Jack Stevens View Post
    The challenge is there are a number of ways to do this, none of which follow the standard. Can someone collect all the methods and list them here so I can think about how to implement them?
    Jun 2009
    2,845
    Ahh you're thinking much more industrial than I was.
    I was envisioning something in a case more like one of the HAMMOND ENCLOSURES.
    I've made a few false starts on this myself. I've got a basic design around a 16F688 (because I know we tend to have them lying around),
    but never made it to the stage of having the board(s) made. Again.. I failed to design to the enclosure, so the design has sat idle for months now.
    Looking forward to watching this thread.
    WI
    2,611
    I think its because I really like that case but maybe I should pick an alternative case that is more accessible via digikey or mouser. Thanks for the suggestion I will continue to look into cases before I get too deep and regret it. ;)
    Sep 2008
    Baulkham Hills, NSW
    2,608
    These are the ones I found when settling on the Sum method.
    Start Address (Sum)
    Start Address = Ch1 + Ch2
    Start Address (Units)
    Start Address = Ch1*100 + Ch2*10 +Ch3
    Start Address (Modified Sum)
    0 to 255
    Start Address = Ch1 : Ch2=0
    256 to 512
    Start Address = Ch1 +256 : Ch2=1
    [B][I]Matt[/I][/B]
    WI
    2,611
    Start Address (Sum)
    0 to 255
    256 to 512
    How do the devices know that what is being sent is an address and not real data? Start code > 0x00?
