After a fruitful endeavor of compiling and installing mono from source, downloading Vix 3.0 to my Ubuntu 10.10 x64 machine, and getting the startup screen to run... It crashed :/
Missing method System.Windows.Forms.SplitContainer::BeginInit() in assembly /usr/local/lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll, referenced in assembly /home/josh/Downloads/Vixen/Common/CommonElements.dll
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.MissingMethodException: Method not found: 'System.Windows.Forms.SplitContainer.BeginInit'.
at CommonElements.Timeline.TimelineControl..ctor () [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) CommonElements.Timeline.TimelineControl:.ctor ()
at VixenModules.Editor.TimedSequenceEditor.TimedSeque nceEditorForm.InitializeComponent () [0x00000] in <filename unknown>:0
at VixenModules.Editor.TimedSequenceEditor.TimedSeque nceEditorForm..ctor () [0x00000] in <filename unknown>:0
at (wrapper managed-to-native) System.Reflection.MonoCMethod:InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&)
at System.Reflection.MonoCMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at System.Reflection.MonoCMethod.Invoke (BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in <filename unknown>:0
at System.Reflection.ConstructorInfo.Invoke (System.Object[] parameters) [0x00000] in <filename unknown>:0
at System.Activator.CreateInstance (System.Type type, Boolean nonPublic) [0x00000] in <filename unknown>:0
at System.Activator.CreateInstance (System.Type type) [0x00000] in <filename unknown>:0
at Vixen.Module.Editor.EditorModuleManagement._GetEdi torUI (IEditorModuleDescriptor descriptor) [0x00000] in <filename unknown>:0
at Vixen.Module.Editor.EditorModuleManagement.Get (System.String filePath) [0x00000] in <filename unknown>:0
at Vixen.Sys.ApplicationServices.CreateEditor (System.String sequenceFilePath) [0x00000] in <filename unknown>:0
at VixenApplication.VixenApplication.<initializeEdito rTypes>b__2 (System.Object sender, System.EventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripItem.OnClick (System.EventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripMenuItem.OnClick (System.EventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripMenuItem.HandleClick (Int32 mouse_clicks, System.EventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripItem.FireEvent (System.EventArgs e, ToolStripItemEventType met) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:FireEvent (System.EventArgs,System.Windows.Forms.ToolStripIt emEventType)
at System.Windows.Forms.ToolStrip.OnMouseUp (System.Windows.Forms.MouseEventArgs mea) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripDropDown.OnMouseUp (System.Windows.Forms.MouseEventArgs mea) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WmLButtonUp (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStrip.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripDropDown.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlWindowTarget.O nMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlNativeWindow.W ndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Didn't know if anybody else had tried the effort yet. It would sure be nice to see a semi-cross platform engine available.
Heck. I'd even be happy if just the output modules worked on my *nix machine... Could sequence on my home computer than ssh into my show computer and play from that![]()
