Results 1 to 4 of 4
Thread: Moving Message Display - From the Grinch
    Lightbulb Moving Message Display - From the Grinch
    When I was finding information about the grinch controller I realised it was doing the same thing as a moving message display would do, shifting data bits and enabling the output. So I decided to build one using 5 of the MBI5027 IC's per row of LED's and used 7 rows of LED's so that characters can be displayed using the common standard of a 5 x 7 matrix of LED's per character. The Moving Message display can be driven direct from any of the switching controllers found on this forum but it does use 8 of your valuable channels to do it, 7 for data and 1 for the clock. Each of the characters, numbers or symbols are programmed directly in to the vixen grid so making it very versatile as to what you display. I use it for displaying the radio frequency to tune to, song title and my website address. A little more information including some pictures and aVixen screen snap can be found on my website tyzzerslights.org.uk/Display2011.htm
    196 + 12 Channels, P4 1.8GHz, Grinch & Parallel12, Win XP Sp3, Vixen 2.0
    http://tyzzerslights.org.uk/
    7,781
    Default Re: Moving Message Display - From the Grinch
    It sounds like you've reinvented the LEDTriks - it uses essentially the same process (and chip!) neat that it can be driven directly within the sequence!
    Brian
    Halloween in San Jose! - FB
    I thought the LEDtriks display would be far more complicated than this as I think I have seen it do all sorts of display capabilities like rotating, up/down scroling etc. I was trying to build something easy to program, may be I need to re-read up on the LEDtricks info.
    Dec 2008
    Wichita, KS
    119
    Your way of programming the LED matrix using the Vixen grid is quite clever!
    While the circuitry of the ledtriks may be a little more complicated, programming it with the Vixen plugin that automatically generates sequences with a font is pretty convenient.
