Ok, I have went about as far with the troubleshooting as I could take it, so now I am asking for some help.
A little background.
I broke the number 1 rule of if it is working don't fix it. All was working when I had a tune to (set to 100%) and a thank you scrolling text (set to 50%). We are expecting a community group to the show and I wanted to change the thank your to a welcome to the show scroll. I have attempted to revert back to the original setup but the LTC remains broken.
I am using ltc09.exe, vixen 2.1.4 on an XP professional PC
I currently have three triggered launchers, (1) is my tune to radio station (100%) (2) is a thank your for your donations (50%) (3) is to kill all running LTC.exe (25%)
If I run the LTC command from command line it executes fine.
If I run the sequence and the launcher plugin the commands executes fine.
If I have my program kick off with the scheduler I could see the dos window open but the command flash by so fast I can't read the screen.
When I open the program there are the 3 options to run the plugins; Use programs's plugin setup, Use a profile and use each sequence's plugins. I have tried all three with the same results.
It seems to be an issue with the scheduler but I can not figure out what it could be.
Also I see some people are running ltc11_exe. If there is a newer version LTC if someone could point me to the download page being I have done the searches and still can't find a place to download the file.
Any help will be greatly appreciated.
