Results 1 to 6 of 6
Thread: Dimmers, which one to build?
    Vancouver Island
    33
    Default Dimmers, which one to build?
    Currently using an Olsen 595 on/off for my first year. I would like to go to 256 channels on dimmers.
    What one should I build?
    I spent hours re-drawing the schematic and double sided boards for the olsen 595 with the horning dimmer in Eagle CAD. Has anyone built this one? After looking at it many times, I am wondering if this is the one to build. I just can't see with this model that the lights would dimm smoothly, plus it seems like an awful waste of channels.
    Any input would be appreciated.
    Thanks, Barry
    Attached Files Attached Files
    If it's not broken, fix it anyways
    South Weber UT
    285
    Default
    Go Renard, IMHO.
    If you want to do it ALL yourself -- the boards are easy to etch and parts are easy to come by. If you want a head start -- get in on a Coop and start with a sound design and proven parts list.
    Cowes, Victoria, Australia
    590
    Default
    Go a Ren64 to swap for the 595, it has no on board ssr's, and will use the ssr's that you had used for the 595. Not sure if you would want to home etch one tho, or if it is even possible.
    Kevin Lang
    64 Channel Olsen 595 64 Channel Grinch 4 Xmus Ren16's
    Running Acer P4 3.0 GHz and 1.00GB Ram Win XP
    Mooresville, NC
    5,175
    Default
    A renard 64 is not for home etch. At least not at the size it is at. It would be one huge board to be home etch.
    Vancouver Island
    33
    Default
    Is there anywhere that I can get the boards?
    Or, Top and Bottom layers for a photo etch?
    Any help would be appreciated.
    Just a note: this will be for my 2008 display, I just like to get an early start.
    Thanks, Barry
    4,181
    Default
    Send a pm to wjohn, he usually has some.
    It's not a home-etch board by a long shot. Apart from being a two-layer board with the need for lots of feed-throughs, the traces are too narrow (.010") and the spacing too small (.0075", oops) to consider home-etching, even by Wayne.
