I bought mine in your first group buy in 2011. Took it to work (I'M a TWO-WAY radio bench tech for the last 20+ years) Put it on my test equipment and all looked ok thought the output was a bit low but though that maybe my service mointor just didnt like the 100K wide signal anyway. Set it up at home for my display into a diople antenna (at no point was it powered up with out a 50 ohm load or a matched antenna) and i only got about 100' of range
.. took it back to work and tested it again this time looking up the specs first. I found that my unit had -65db of output and it should of had +8 db that a massive difference. Started trouble the transimitter and found that i had a -20db signal out of the IC into the final output transistor and -65db at the antennna port. So being so close to show time I replaced the final output transistor (marked R25) and this got me back on the AIR with a good solid +8 or so db signal.
So yes i think that VAST should have a 2 year warranty. they could also send me a couple of spare output transistors or i would be glad to exchange my FM02 for a new unit if they like.
I it would be best to have 2 of these units for your display.
