Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: SSREZ, TA-200, RJ45 oh my! - help with RJ45 in TA-200
    Jan 2011
    Midlothian, VA
    132
    Default Re: SSREZ, TA-200, RJ45 oh my! - help with RJ45 in TA-200
    Excellent! Thanks everyone! Looks like I will be moving some cords around.
    Lombard, IL
    263
    I actually lay the wire over the top of the gromet. It has a little give, so it will bend when you close the lid. Still maintain a water-tight box. Works for me and most of my boxes end up under snow. The only thing you have to do ia make sure the boxes stay right side up. If they end up up-side-down, they will fill with water.
    (2008) Grinch for 64 channels
    (2009) Ren64XC (2) for 128 channels
    (2010) Ren64XC (2) and Ren24LV for 152 channels
    (2011) Ren64XC (3), Ren24LV, and Ren24SS for 240 channels
    (2012) Ren64XC (3), Ren24LV. and Ren24SS(3) for 288 channels
    (2013) Ren64XC (3), Ren24LV, Ren24SS(3), and Ren16SS(4) for
    Also LEDTriks(2), TriksC(2), and LED Panel Sets(2)
    7,787
    I don't even use the grommets in mine - the wires pretty much fill up the hole and unless someone is out there with a hose, the water shouldn't be going up into them anyway. Never had a problem with this myself but we only get rain here in the winter.
    Brian
    Halloween in San Jose! - FB
    Eagan, Mn.
    1,515
    I cut a slit in the grommet, slide the wire thru the slit then slide the grommet into place.
    Brian
    Harrisburg, PA
    383
    BE CAREFUL -- I had a helper try to shove the RJ45 through the grommet while it was in the enclosure and he ended up with bloody fingers. When we setup I go over saftey and that is one of the examples. :-)
    Left to Do:
    2011!!
    Thunder Bay, Ontario, Canada
    21
    All I did was cut a piece of cat5 about 6 inches long, put a plug on one end, slide it through the hole & plug it in. Then I crimp a connector to the end that is hanging outside of the box and put an RJ45 coupler on it. Never have to open the box after that or be concerned with leaving the gromets on long cables. Just my 2 cents worth lol.
