I finally got around to making the sACN code its own object. The only decadency it has is the W5100 driver. Having a stand alone object allows you to change between Ethernet protocols (sACN and ArtNet) without rewriting a bunch of parent code. The parent will still need to provide the IP settings, object initialization, and call the data collection methods. This is a first pass and I may change some things, my goal is to make it as easy to use as the DMX object.
You can get it from the google project site now. Once I have a little more testing on the ETH_128 project I will update that.
