Results 1 to 5 of 5
Thread: PLC Program for Lighted Arches
    7
    Default PLC Program for Lighted Arches
    Seems I have been hijacked into doing some lighted arches and some other things i guess. Looks to me that a digital 120vac output 8 channel 2amp relay card will work. Has anyone else done it this way, and if you did, what type of timing did you use between channels? I normally do industrial controls, but some insight on timing or other issues would be helpful. Need be I have an additonal 16 channel,. Looks like there are many variations of moving the lights up/down, center to both ends, etc. I am not beyond copying a working program or any additonal idea's. I could also make 3 arches move together as a 2 amp channel will do the light sets in sync (should work). We are new to this type of thing and time is moving quickly by. Do most people us PLC's or something else?
    THANKS
    2,192
    Default Re: PLC Program for Lighted Arches
    Ginger:
    As others have said in other threads: welcome to the club.
    Most of us handle things like leaping arches via a 120vac controller -- how many channels depends upon how many arches and how many channels per arch. I would hope by now you've visited the "Arches of Light" subforum where you can read up on how people here do this.
    When you use the term "PLC," I assume you mean "programmable logic controller," which is a foreign term here. The controllers discussed here are do-it-yourself projects; the engineers amongst us design printed circuit boards and those are then offered for sale (usually at no price markup) or as files for self-etching; lightmasters then buy components (from Mouser or one of the other electronics mail order houses), solder up the results and have a controller.
    The controllers here use one of two basic protocols: DMX-512 or Renard (the latter is a protocol designed by people here and documented on the wiki; the former is the entertainment lighting system). The Renard can be driven serially or via RS-485. The controllers use either Microchip-based microcontrollers or Atmel microcontrollers.
    Most people here share their hardware designs as schematics and firmware code as C or assembly (there are exceptions).
    Controllers can be either centralized, where the solid-state relay is housed with the logic circuits, or decentralized, where the SSR is remote from the logic circuit.
    We mostly synchronize our lights -- leaping arches and others -- with music and use the Windows application Vixen to do this. We are open about sharing our Vixen files and if you find a song you want to use and post, someone may certainly have a synchronization file they'd be happy to let you use.
    Please visit the wiki's "Beginners" section, where a huge amount of info is available.
    HTH.
    \dmc
    ________________________
    2,192
    Double post
    7
    thanks very much for the information!
    May 2009
    Murrieta Ca
    392
    Ginger
    Welcome to DIYC, the hobby that never ends.
    When I first started looking into this hobby, I too was going to use a PLC, but found it to be way to restrictive. The controllers you find here in the WIKI work much better, are cheaper to build, and are a lot easier to communicate with. A lot of us program our songs with 50ms changes in our sequencing. Thats a lot of data for the PLC to handle. Also if you use something like the REN series controllers, you have the ability to dim your channels. When building arches, I have found this to look a lot better. The arches I built last year are all LED, with 8 segments per arch. I used 10 foot piece of 3/4 PVC EMT. The sequencing I found that works the best is 100 ms on with a 200ms fade to off. That way it looks like a tail on the arch.
    Everyone does things different here, and that is the fun part. It always keeps your mind thinking about how to improve your own display.
    Good luck, and have fun with this. Oh and one last thing, on this forum, there is no such thing as a dumb question. So feel free to ask.
    tweist
    736 Channels
    65+ Wireless Ren controllers
    [COLOR="#0000FF"](2013) 25+ houses[/COLOR]
    (2012) 20 houses total
    (2011) 13 houses total
    2012 video
    [url]https://www.youtube.com/watch?v=_KVM_EPKYMM[/url]
