Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: W5200 four more sockets
  1. #51
    WI
    2,611
    Default Re: W5200 four more sockets
    Quote Originally Posted by jstjohnz View Post
    So far the driver seems to be working fine.
    Faster timing will just be icing on the cake. Great work Ben.
    Thanks, glad to hear it is working for you.
    I went to a Propeller meeting this morning and spoke with a guy who wants to do ethernet stuff for a project he is working on. I gave him a W5200 board and as luck would have it he's an accomplished ASM programmer so he is going to take a look the code to see if it can be sped up.
  2. #52
    WI
    2,611
    I've posted the W5200 driver to the Parallax OBEX. http://obex.parallax.com/objects/869/
    After posting I solicited methods for speeding up the SPI speed on the Propeller forums. Long story short I think its as fast as it can/will be. So I will move onto implementing "burst" mode which will indirectly speed up communications. Instead of writing 40 bits for each data byte in a string, it will write 8 bits for each byte after the first byte has been written.
  3. #53
    WI
    2,611
    Big thanks to jstjohnz for finding the error of my ways in regards to getting the driver to communicate faster. The "trick" was keeping the read at 10mhz and making the write 20mhz. I will be updating the PropController site and Parallax OBEX with ver 1.1 once I give it a spin (pun intended).
  4. #54
    WI
    2,611
    New driver has been tested and has been uploaded, enjoy.
  5. #55
    WI
    2,611
    jstjohnz updated the driver to support burst mode, which is unique to the W5200. He is seeing an increase of almost 4 times from the W5100 read/write speed with this change. Once I review the code and test it I will post it to the PropController repository and the Parallax OBEX.
  6. #56
    WI
    2,611
    Posted in both location, current version is 1.2...enjoy
