Results 1 to 9 of 9
Thread: RGB Spinners
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default RGB Spinners
    ( Note to MODs - I think this is the correct section if not please move)
    A fellow country man created what he called an RGB Spinner. Check out his video over at ACL.com here.
    I liked the idea concept, so started to plan my version.
    I built the first prototype on Saturday afternoon. It was more off a POC for show the bride and got the "I like it"
    I am in the middle of making the second prototype that also encloses the controller as part of the display item.
    Check it out here
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default Re: RGB Spinners
    Prototype1 used a 100mm PVC end cap. I free hand milled the top for nut clearance
    Hub was too small for Controller PCB.
    Prototype 2 uses a 150mm PVC end cap. No need to mill the front face & the controller fits real nice.
    (more to come)
    Cape Coral, FL
    1,041
    That looks a lot like Henri's Star he made a few weeks ago.. http://doityourselfchristmas.com/for...ght=superstrip
    he made the same thing almost but out of Franks SuperStrips
    Got 100 of These connected to 10 of These controlled by one of These! Let's FLASH!
    Sep 2008
    Baulkham Hills, NSW
    2,241
    It is probably too late in the season to add these and do them justice, but here is a quick test video.
    Melbourne Australia
    551
    Never too late Matt! :p
    Nice work on the controller as well. That's a pretty small footprint!
    Mar 2010
    Albion Park NSW Australia
    287
    Very nice work Matt, im sure if you have the motivation you will add them in this year. It would make a very nice inclusion into your display.
    WWW.AVERYEDDYXMAS.com
    http://forums.auschristmaslighting.com/index.php
    Download the AusChristmasLighting 101 manual from http://auschristmaslighting.com/foru...ic,1889.0.html
    Your just jealous because the voices only talk to me
    8,019
    There must be something wrong -- they keep changing colors!!!
    Looks great, Matt!
    dirknerkle
    This looks terrific - I think I'll cobble together a few of these for 2013. What size is the PVC going into the "hub" (3/4"?) and where did you find the threaded fittings to tie them into the hub? Home Depot?
    Sep 2008
    Baulkham Hills, NSW
    2,241
    I used 20mm grey conduit
    the threaded fittings are Clipsal branded "Conduit adaptors plain to screwed" part number 263/20GY
    They look like Home depot http://www.homedepot.com/Electrical-...&storeId=10051
    Check it out here
