Results 21 to 30 of 43
Thread: Run a Renard without a computer
    Mar 2010
    Leesburg Florida
    2,490
    Default Re: Run a Renard without a computer
    OK, I've got some sample code here that flashes all of the lights on and off at about a two-second pace (don't time me...) when there isn't any incoming data. It doesn't send data downstream, although code could be added to do so at the spot where new code is hooked in.
    I'm not sure if I want to upload the code for general use yet, for fear that it would be confused with the regular Renard start_address firmware. Any suggestions (or volunteers) for avoiding a general mess at this point?
    PS By 'here', I mean on my computer.
    I'd like to try it an modify it for the PIC18Fxxxx stuff if thats OK with you.
    5,321
    Quote Originally Posted by Mactayl View Post
    Sent. Not that there is much to it. It's just a counter that is incremented at the end of each PWM cycle (120 times/sec for 60 Hz, 100 times/sec for 50 Hz), and is reset whenever a character is received. When that counter overflows the user code is called.
    Mar 2010
    Leesburg Florida
    2,490
    I will try it tonight.
    Thanks Phil,
    Mar 2010
    Leesburg Florida
    2,490
    Took a quick look at it and as for other controllers down the line if they had the firmware installed they would also start running there own sequence and you would not need to transmit any data from the first controller to the other controllers as the they would respond to the Renard data stream as soon as they receive Renard data correct
    5,321
    Yes. It could be done either way - each controller could run independently when the data stops coming, or the lead PIC could start sending data when it stops receiving data. In the latter case all of the downstream PICs would see a one or two second gap in incoming data before the first PIC starts sending, so they would need to be programmed to ignore that gap (i.e. use current, unmodified firmware). At the moment that duration of that gap is hard-coded, but it would be fairly easy to make it configurable.
    Mar 2010
    Leesburg Florida
    2,490
    I really think a lot of folks would like this option during a break in the show where there lights could just flash independently of there show or run them in a random sequence before of after there show or just about anything else.
    Avon Lake, OH
    479
    How many bits of sequece data could be stored on the PIC16F688? It would not be too hard for me to write a plugin to output the bits representing the data into a .asm file that could be compiled. Or maye another PIC16 that has the same pinout and more data? Just a thought.
    Erik
    Give back to the site that has given so much, become a [URL="http://doityourselfchristmas.com/forums/payments.php"]supporting member[/URL].
    Sheboygan, WI
    1,684
    This would interest me greatly for my Ren48 with Super Strips. I leave them up all year but don't run them due to them needing a PC. I would run them all night long in fading patterns if it were possible to do it without a PC.
    [URL="www.diyledexpress.com"]www.diyledexpress.com[/URL]
    [URL="www.facebook.com/diyledexpress"]DIY LED Express on Facebook[/URL]
    [URL="www.crazychristmaslights.net"]www.crazychristmaslights.net[/URL]
    10,283
    I want to implement the code on the Ren4Flood at some point so I'd be interested...
    Brian
    Halloween in San Jose! - FB
    2,144
    Quote Originally Posted by erm213 View Post
    I think that depends on what format you store them in. If you use 1 byte per channel per interval, you could use up the available flash memory ((4K words - what is used for the firmware)/#channels/#intervals you want), or if you stored them as bitmaps or threaded function codes, you could get potentially a lot more in there.
    don
    Click for display details >>
