Results 1 to 7 of 7
Thread: Reflective Strobe Lights - Cheap!
    Thumbs up Reflective Strobe Lights - Cheap!
    I got this idea from a Halloween store locally.
    Read more here: http://www.highcountrylights.com/blo...eflective.html
    Costs: $7. I already had the strobe light, C9 socket, and vampire plug.
    29,382 channels to play with in 2013.
    High Country Lights | Free Sequences | Facebook | Video
    7,765
    Default Re: Reflective Strobe Lights - Cheap!
    Do you have a video of the effect of adding the reflector over a straight strobe?
    Brian
    Halloween in San Jose! - FB
    Yes. I just uploaded on Vimeo and embed the links on that blog.
    Mar 2010
    Leesburg Florida
    2,490
    The reflector strobe in your video makes a big difference in the on the total effect of the strobe, nice job.
    Some days... things click but most seem to be stuck in the mud. lol
    Thanks.
    8,019
    Well done! There's no question that if you can capture a light's output and direct it into a specific direction instead of 360 degrees it will give you a brighter effect! I used a lot of reflectors when I was a photographer and other ways to achieve a similar effect at even lower cost are to use kitchen mixing bowls or even aluminum plates. One of my favorites were small plastic tupperware bowls that I'd spray-painted silver on the inside and black on the outside. Being non-electrically conductive and flexible, I could put that over all kinds of things, cut the hole larger and force it over mounts, or even cut the whole side of a bowl and mount it from the back of the light instead of the front. Plastic works okay for strobes but not hot, 1000-watt modelling or fill floods though... it melts...
    dirknerkle
    of course today we use 1000 watt eq. CF bulbs that are daylight balanced and cool to the touch.
