Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 114
Thread: Holiday Coro Singing Pumpkin
    8,026
    Default Re: Holiday Coro Singing Pumpkin
    Project update....
    I cut four, 1" long sections of PVC and mounted them on the front of the pumpkin as standoffs. Now I can at least push the bulb side against a wall and the bulbs will be secure. (I love PVC!!!) (Not shown - I screwed a couple pipe brackets onto each vertical side of the big pumpkin frame. For mounting in the yard, I'll just drive a couple sections of rebar into the ground and slide it down over them.)
    Here are the small pumpkins. These are actually plastic treat buckets I bought at Target for $1 each. But because they didn't have a top, I bought some plastic orange plates, cut the rims off and with a few dollops of silicone glue they fit perfectly on top. For pumpkin stumps, I cut a short 3/4" section of PVC that was painted green and glued it to the tops.
    I used a fender washer and 1" sheetrock screw through the bottom and mounted them on two sections of lumber I'd painted black. This will make them easy to store and especially easy to set out. And they're not likely to blow around, either.
    With my Dremel and a diamond saw I cut a V-shaped flap in the back/bottom of each for wiring access and placed a string of 20 mini-lights in each.
    This completes this project for me... great fun. I wonder what life will be like when I grow up???
    dirknerkle
    Dec 2008
    Carmel, IN
    445
    Absolutely awesome, and elegantly simple to boot!!!
    This is definitely on my list for next year!
    Tom
    Facebook - Christmas on Victory Celebration of Lights
    2009 - 328 channels, 48,500 lights
    2010 - 448 channels, 61,100 lights
    2011 - 480 channels, 68,000 lights
    2012 - 480 channels, 68,000 lights <---- same as 2011
    5 x Ren-SS8 --- 12 x Ren-SS16 --- 4 x Ren-SS24 --- 5 x Ren-24
    3 x Ren-24LV --- 4 x Ren-48LSD --- 2 x Ren-64XC --- 1 x Helix
    50 x SSR (mix of oz and ez and soon to be neon)
    Yes, I have excess capacity!!!
    Avon Lake, OH
    479
    Looks great. Now why do you want to grow up? This is concerning.
    Erik
    Give back to the site that has given so much, become a supporting member.
    Nov 2008
    Covington, GA
    74
    Hey Dirk - how far apart are the lights around the perimeter. I am making some coro cutouts for Christmas and trying to figure out how far apart to drill the holes and still get a nice look.
    Jan 2011
    Port Richey, FL
    437
    You are already growed up. Just your mind has to catch up...LOL
    8,026
    Quote Originally Posted by RobDude30 View Post
    I'd say they're slightly less than 3/4" apart, and it's the same distance whether it's an eye, part of the mouth, or whatever. In cases where lines overlap/intersect, they are closer than that, of course.
    Having said that, I want to say that buying the piece from Holiday Coro made it so easy -- well worth the money, I feel. The board is opaque black so nothing shows through, the holes are already there for you, someone has already traced on the back of the board to show which sets of holes are for what, and you get three sequences (and MP3 files) along with it, ready to go -- the time that saved alone was worth the $$ to me! But on top of all that, the board comes folded and shipped inside -- what else -- MORE CORO! So you get not only the pumpkin, the sequences and music, but you get a 4' square piece of regular coro (white translucent) to boot that you can use later on for something else!
    So you might consider buying one instead -- the holes are uniform and perfectly sized for mini-lights (or M5 LEDs), you get all the other stuff -- it's a steal at the price!
    dirknerkle
    Spacing is a tricky thing - for some areas you need to have them fairly tight, such as where you have lots of curves or jagged angles and you can space them out where the eye can "interpolate" between the lights such as long separate lines. Some places like on mouths, eyes you'll also need them close. I would *highly* recommend drawing out the vectors on transparency, then using another transparency laid over the vectors, layout the dots where you have bulbs so you can workout the spacing. You'll need these anyway when you do the projector. Ideally this is done in CAD where it's trivial to test many different spacings.
    Be sure to flip your design when you trace it to the back side so it comes out correctly. Here is what you'd be looking for when you are done:
    Clarksville, TN
    236
    I am with Dirk on this one. I had been on the fence for a while on weather or not to buy the coro. The addition of the files put me over the edge, especially after building some coro's my 4th of July show.
    Tony
    Live since 2007
    Moving up to 512 channels and 45,000 lights of Blinky this year.
    Putting the Yule back into Yuletide.
    Nov 2008
    Covington, GA
    74
    Thanks guys for all of the input. Very helpful!
    I do agree that purchasing pre-made would be much easier, but I am working on some cutouts of my own design. So, wish me luck on all of the hole drilling/punching.
    Rob
    Dexter, MO
    229
    Well again you have inspired me Dave. Made a trip to WalMart today and 6 for .97 each. Now to put it together. Where did you get the plates?
    Rick
    2008 It began...6 Channel Mr Christmas
    2009 8 channel simple controller
    2010 Olsen 595 and Ren 24
    2011 595, 2 Ren 24's and one Ren 8
    2012 Wireless for 200 Channels
    2013 ?????
