Page 1 of 11 123 ... LastLast
Results 1 to 10 of 106
Thread: 10 Watt RGB Flood Light
    Sep 2007
    Pearland, TX
    112
    Default 10 Watt RGB Flood Light
    Not sure if anyone is interested but I thought I would post so that my work might benefit others. I found a 10 watt RGB floodlight on E-Bay that was small and waterproof. It comes with a remote and runs on 120VAC. The unit has its on 12VDC power source.
    What I did was create a small circuit using H11A1 (optoisolators transistor output) and hijack the gate on the board inside the light. I run my board off the 12VDC from the built in power supply and lift the gates from the original board. Merely connect the three wires from the 3K resistors to the optos to the gates. I grounded the gates through a 10K resistor.
    If anyone wants more info please let me know.
    Sep 2007
    Pearland, TX
    112
    Default Re: 10 Watt RGB Flood Light
    By the way I have built a couple of the Mighty Minis, and 5 of the Rainbow Floods, these 10 watt lights are as bright.
    Here are a few more pics.
    Dec 2009
    Gresham, OR (45.483992, -122.453879)
    1,591
    I've seen these on Alibaba, now I may have to get a couple! Good work on the hack. -- John
    Columbus, OH
    1,811
    Can you tell us how to find these on ebay or does someone have an alibaba source they can link us to?
    Quote Originally Posted by joeytx View Post
    Dec 2009
    1,591
    Your wish is my command: Alibaba
    Oct 2008
    San Jose, CA
    7,787
    Quote Originally Posted by macebobo View Post
    close - that one is not waterproof but there's probabaly one on there somewhere!
    Brian
    Halloween in San Jose! - FB
    Dec 2009
    1,591
    Does not say waterproof, but it does have an ingress protection rating of 6/5 (6=Totally protected against dust, 5=Protected against low pressure jets if water from all directions - limited ingress permitted)
    This one does say waterproof, but it is IP65 also.
    Nov 2009
    378
    Is this it?
    http://www.ebay.com/itm/Remote-Contr...item35b4df9bc5
    This one matches the picture - but costs just a bit more..
    http://www.ebay.com/itm/Waterproof-R...item4841b35772
    I searched on: remote rgb flood
    How does this compare to the DIY versions I've seen posted on here? Probably won't get one this year but definitely next, I have a good spot for one or two.
    Jason
    Nov 2010
    Cape Coral, FL
    309
    Here is the same RGB light from Ray Wu who I have purchased other items from before.
    http://www.aliexpress.com/fm-store/7...40V-input.html
    Apparently there is a 30 watt version too.
    Brian
    Help Support Do It Yourself Christmas.com
    For just 6 cents a day you can help someone with their Christmas Light Addiction Problem.
    Click here to Become a Supporting Member and help spread the CLAP!
    Click here to show/hide my display details...
    My Light Show Videos: http://vimeo.com/brianandheather
    Sep 2007
    Pearland, TX
    112
    Sorry, had church this morning. Here is the link for the one I got:
    http://www.ebay.com/itm/Waterproof-R...item4aae2c7ea6
    There are all about the same, they very in price a little. By the way I received mine in less than 8 days.
