Thread: Punching Coro
    Jun 2008
    Woodinville, WA
    54
    Default Punching Coro
    I don't remember ever seeing this method for punching coro.
    I started a project today that requires me to punch a TON of holes in coro. After playing around for awhile figuring the best way to do this, I pulled out my handy dandy, WAY old, cheap, $5 special, soldering iron that I burn holes in my stobe lenses with. Using this is just as fast as an awl or drill, just much cleaner. No where near as much push through on the material. Very easy, and not hard to do at all. Wish I would have thought of this a few years ago.
    Mark Zembruski
    I have the CLAP - Christmas Light Addiction Problem
    www.woodinvillewonderland.com
    ~ Christmas is not a time, it's a state of mind ~
    Default Re: Punching Coro
    just make sure its an old tip an in a well ventilated area
    2012 Checklist:
    7x mini floods
    2 RGB 9Ch Led Leaping Arch - 630Leds, 9 channels per colour - 27ch's each
    Mega Tree 5m - 14x r g b w leds - 54ch's
    10x RGB CoroStars - 6 RGB 5050 Leds in each - 3ch
    1x RGB Merry Christmas Sign
    - 42ch's
    2x 3section RGB Coro VU Meters - 27ch's each
    RGB Led Mega Star - 24ch's, 3ch each point of star
    10x Ledancer tubes
    150x ACL Led Strobes
    1x RGB Coroflake
    http://www.youtube.com/watch?v=bH7gDBDrFok
    Apple Valley, MN
    3,220
    I hardy ever have a tip go bad and I usually don't have a need to do a TON of anything other than soldering with my iron.
    If you want to poke holes, just wrap a piece of wire around the tip. What I do is first wrap the wire around just the tip to get the shape, then pull it off and wrap the rest around something slightly smaller than the heater shaft. Then twist it onto the iron like a screw so that it will be tight and won't move.
    I've done this also when I need to cut plastic; just use small wire.
    This works best if the iron has a variable temperature control so that you can apply just enough heat without smoking it.
