Results 1 to 4 of 4
Thread: Trouble converting LOR to Vixen
    Jan 2010
    Ocala, FL
    85
    Default Trouble converting LOR to Vixen
    I am using the program that was posted on this site a while back that converts LOR to Vixen sequences. All has been going good all have converted till tonight. I keep getting the below listed error message. When it comes to these items I am dumb can anyone help me out & tell me what it is all about. I have redone this sequence on 2 different computers one with XP the other with Vista & have the same results. I am thinking it maybe the way the voice over was done that is causing the error.
    Thanks Mike
    4219
    Stack Trace:
    lor2vix.Convert.convert(Convert.java:259)
    lor2vix.LOR2VIXView.convertToVixen(LOR2VIXView.jav a:275)
    sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
    sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source)
    sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
    java.lang.reflect.Method.invoke(Unknown Source)
    org.jdesktop.application.ApplicationAction.noProxy ActionPerformed(ApplicationAction.java:662)
    org.jdesktop.application.ApplicationAction.actionP erformed(ApplicationAction.java:698)
    javax.swing.AbstractButton.fireActionPerformed(Unk nown Source)
    javax.swing.AbstractButton$Handler.actionPerformed (Unknown Source)
    javax.swing.DefaultButtonModel.fireActionPerformed (Unknown Source)
    javax.swing.DefaultButtonModel.setPressed(Unknown Source)
    javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(Unknown Source)
    java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
    java.awt.Component.processMouseEvent(Unknown Source)
    javax.swing.JComponent.processMouseEvent(Unknown Source)
    java.awt.Component.processEvent(Unknown Source)
    java.awt.Container.processEvent(Unknown Source)
    java.awt.Component.dispatchEventImpl(Unknown Source)
    java.awt.Container.dispatchEventImpl(Unknown Source)
    java.awt.Component.dispatchEvent(Unknown Source)
    java.awt.LightweightDispatcher.retargetMouseEvent( Unknown Source)
    java.awt.LightweightDispatcher.processMouseEvent(U nknown Source)
    java.awt.LightweightDispatcher.dispatchEvent(Unkno wn Source)
    java.awt.Window.dispatchEventImpl(Unknown Source)
    java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    java.awt.EventQueue.access$000(Unknown Source)
    java.awt.EventQueue$1.run(Unknown Source)
    java.security.AccessController.doPrivileged(Native Method)
    java.security.AccessControlContext$1.doIntersectio nPrivilege(Unknown Source)
    java.awt.EventQueue$2.run(Unknown Source)
    java.awt.EventQueue.dispatchEvent(Unknown Source)
    java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
    java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
    java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
    java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    java.awt.EventDispatchThread.run(Unknown Source)
    Modify message
    10,283
    Default Re: Trouble converting LOR to Vixen
    I think the LOR2VIX program requires the newer LOR sequence format - this may be the older version. Can you post the sequence?
    Brian
    Halloween in San Jose! - FB
    Jan 2010
    Ocala, FL
    85
    Problem solved one of the board members found & corrected the problem below are the findings.
    I converted them for you, The problem that I saw was you ran your sequence right to the end of the timing grid. The LOR converter and Vixen sometimes can't handle sequences that go to the end of the timing grid so I turned off all of the channels in the last column grid then it converted fine which you will see in the .lms file I included. You should also make sure that none of your sequences made in Vixen do not have anything on at the end of the timing grid because that will also cause hang-up problems when you try and run your show with multiple sequences.
    Hope this helps."
    Mike
    Mar 2010
    Leesburg Florida
    2,490
    Quote Originally Posted by mmais68569 View Post
    Hope this helps."
    Mike
    Enjoy;)
