Results 1 to 10 of 25
Thread: PVC Farris Wheels
    Eagan, Mn.
    4,061
    Default PVC Farris Wheels
    Number one I hate seeing the forum item still empty. I love the little PVC Farris wheels sized for stuffed animals. The 6-15ft tall range, 4-10 chairs. We've all seen these and the basic frame and pivoting seats are not too hard to figure out (not simple but doable). I would like to see some ideas on the cheap to run them and the hardware to get it done. Anyone here play with this yet?
    Brian
    Dec 2008
    3,922
    Default Re: PVC Farris Wheels
    I couldn't locate it, but I know I saw this somewhere when I was looking at ideas for a train. Much like you are saying and it used a Wiper Motor with Bicycle chain and sprockets to turn the wheel.
    Dark Yard again for 2017
    Still searching for more Time and Money
    Display Facebook Page
    725
    I've seen a couple on ebay made by gemmy.
    http://cgi.ebay.com/New-Gemmy-Christ...item45fc68ae7c
    I know this is DIYC but for about $50 it would probably be less.
    Just a thought...
    Ontario, Canada
    2,020
    Using CPVC (the white stuff) you can slip a 3/4" T coupler directly over a 1/2" CPVC pipe the play/slack/slop is not too bad and if it can be used for Halloween coffin jumpers, It can be used for Ferris wheels on the seat buckets too!
    As for a center hub for the main wheel, a pair of childs rear wheels off a trike 8" diameter, would hide nicely behind a plywood hub plate
    You could even consider Pillow blocks or a mandrel to act as the center hub.
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Jacksonville, FL
    460
    Has anyone ever used a rotating tree base for a center hub? I picked up two in the after christmas sales. It already has a motor and transfers power.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Eagan, Mn.
    4,061
    Transfer of power is the big one. Anything super easy and cheap might not be reliable and need to be covered. And most slip rings that carry enough power are spendy.
    Sent from my SCH-I545 using Tapatalk
    Nov 2012
    Rural Colorado, just East of the Denver Metro.
    345
    I wonder if you could use the brushes from an old alternator, or if they're cheap enough buy them new, and mount them on a larger PVC pipe.
    Jacksonville, FL
    460
    The stands were $30 so I picked one up at 50% off and another at 75% off. Fairly cheap for a motor and hub if I can get to building it.
    Jacksonville, FL
    460
    Wonder if a power line network adapter will work with it...will need some time to tinker.
    Eagan, Mn.
    4,061
    Where did you find the tree stands?
