Results 1 to 10 of 10
Thread: PropController daughterboard extender
    10,283
    Default PropController daughterboard extender
    One thing I think this project may need at some point is a daughterboard extender that will allow you to place the daughterboards at a significant distance from the PropController main board. Greg has this capability on his Helix and it's a great idea. My thought is that it would have the 8-pin SIL connector at one end and an RJ-45 at the other. We could transport 3-signals over 3 pairs and supply power over the other pair. Of course, you would need a set of two for each daughterboard.
    I'll look into drawing something up for this.
    [/SIZE]
    [/COLOR][/I]
    Nov 2008
    Clermont Florida
    753
    Default Re: PropController daughterboard extender
    Was the data sent via a RS485 interface or something? This would totally alleviate about half of my controllers in the show if I could do this.
    WI
    2,611
    Greg's transports 3 I/O pins if memory serves, are you thinking 3 or 4?
    10,283
    It would have to be limited to 3 pins because the extender power has to be supplied via the RJ45 as well. I think this will be OK for most boards. I was thinking of RS-485 but I suppose it could be RS-232 if you wanted more I/O pins transported.
    [/SIZE]
    [/COLOR][/I]
    WI
    2,611
    I knew at some point I would pay for adding that extra pin to each header. ;)
    Nov 2008
    Clermont Florida
    753
    What about using 2x rs485 lines and transporting all of the pins?
    10,283
    Quote Originally Posted by chilloutdocdoc View Post
    Hmm... Personally, I'd rather stick with a single wire - if we need four lines it might be better to use RS-232. I know it will limit the distance and require a different board but I think the benefits would outweigh the requirements of always having to have two cables. Which boards require 4 wires at this point? I know for the LSD port that I only need three - the 32-channel dimmer has all four but - and I'm not sure how/why it's used - but the fourth wire goes to the SSR outputs?
    [/SIZE]
    [/COLOR][/I]
    WI
    2,611
    I know why, and I guess I should tell people this, the fourth I/O is for a 1-wire temperature sensor.
    Nov 2008
    Clermont Florida
    753
    True, if you really need more wires I guess you could use a bcd decoder or a shift register, would slow down the.data, but more pins for less wires.
    10,283
    Well... I'm open to suggestions regarding which chip(s) to use for this. Maxim has a quad driver chip but it operates at 3.3v. This is fine for the Prop side but I am planning to transport 5v, not 3.3v to the far end so this would not work. The 3.3/5v-either versions are wicked expensive - like $10-12 PER chip - way too much... I didn't really want to do an SMD version to make it simpler to make (ideally single-sided home-etch if possible). I was also hoping to make the two ends the same as well to save some confusion.
    I think the 65LBC179 might work using 5v supply on both sides and it seems like it would support 3.3 or 5v logic? I realize it would take 3 of the chips at each end but the chips are easy to find.
    [/SIZE]
    [/COLOR][/I]
