Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 118
Thread: New Project - LEDancer
    4,735
    Default Re: New Project - LEDancer
    I'll take a look at this later today.
    4,735
    BTW, is this what you meant to say?
    Quote Originally Posted by jrock64 View Post
    If the led closest to the controller is channel 14 and the second is channel 20
    4,735
    OK, it's hard to get back to sleep now.
    At the moment I don't have any of the actual coop LED strips on hand, so my comments here are based on laying in bed, unable to get to sleep because I'm thinking about this problem. One thing that I think happened, though, is that some late changes on the LED board design changed it from common Cathode to common Anode (as CaptKirk has been trying to say), and I didn't realize that was what was happening when I made the change at Cory''s request (not his fault, but mine). This has the effect of changing all of the mappings that I had in mind when coding the firmware. It might be possible to fix this in software without totally screwing up the timing, although I'm not sure at the moment. It might also be possible to fix the problem by rotating the LEDs on the strings by 180 degrees, although this is obviously undesirable due to the resulting incompatibility wrt the FAST boards. In any case, I'm getting ahead of myself, as we are still in a diagnosis phase.
    More later.
    Spencer Iowa
    1,164
    Yes I did.
    the first LED to come on was number 14, the second 20, then 26 then 32 ...
    If a picture is worth a thousand words a video must be worth at least a million.
    http://www.youtube.com/watch?v=Gg77kEBa32o
    Thanks Phil.
    After desoldering 3 times I now have leads on the the strip and controller so is easy to change to any order, if that part is wrong.
    Joel
    If I no longer count channels... but instead say I have over 12 universes... Is that too many
    4,735
    Are those the coop LED strips?
    4,735
    If you have a chance, try this new firmware. Use the same sequence that you used in the video, don't try to turn on more than one LED at a time. This is just a test file to see if the LED strips have truly been switched from common cathode to common anode.
    Attached Files Attached Files
    Spencer Iowa
    1,164
    Perfect!!!!:D:D:D
    BTW _BORV_25 needs to change to _BORV_27 as it is not defined in the include file.
    Great work.
    Joel
    4,735
    Perfect??? I didn't expect that, I thought that the LEDs would still be out of order, but in a different manner.
    Anyway, the board design now needs to be changed. The transistors should become 2N3904 or similar, and their collectors should go to +5V, rather than ground. With the firmware change (but not the board change), the PIC I/O current specs would be greatly exceeded.
    Spencer Iowa
    1,164
    So the transistor needs to change from PNP to NPN.
    If that is the only change my board design will actually still work.
    The collector was punching through to a ground plane on the back side.
    That now switches to a +5 and all should be good.
    sux to pay shipping on $9 worth of parts.
    Let me know if that is the only change, and I will get them ordered.
    JOel
    Jun 2009
    Ottawa, Ontario, Canada
    2,811
    Care to share the board design? I'd like to see the layout/pictures.
    Standard Disclaimers apply:
