Page 10 of 10 FirstFirst ... 8910
Results 91 to 96 of 96
Thread: PIC Programmer
  1. #91
    Default Re: PIC Programmer
    Quote Originally Posted by mmulvenna View Post
    Just reprogrammed a chip using the steps in the PDF and it worked fine. I am using mplab 8.43. I suspect a change in the MPLAB version is the cause.
    EDIT: When I get some spare time I will download a newer version and give it a try.
    Downloaded 8.50 of MPLAB. Obviously a change in the software. I have Changed the PDF from "Open" to "Import" and attached it herewith.
    THANKS TO CHICKEN FOR THE CATCH ON THE NEW RELEASE
    JRD...Can you update the wiki with the new file?....Thanks
    Attached Files Attached Files
  2. #92
    Washington, Georgia
    2,376
    I just did. You know the pictures are still for version 8.43 right? Although that should be fine so long as the readers actually read the text.
    DIYC Links:
    Christmas Wiki | Chat
    Ricky, Jrd
    2012
    Fm-02 + Wall Wart Tamer
    2 Simple Renard 32
    15 SSROZ
    Click here to show/hide my past display details ...
  3. #93
    Nov 2010
    Charlotte NC
    442
    Thanks so much for doing this... I had the hardest time finding the file, but after found it programming was simple. Now I need to hook it up to my computer and see if it actually works.
    Side note, the 485 chips on my ren 48lsd, those dont get programmed correct?
    https://dl.dropbox.com/u/95640924/hls560.gif
    1st Year - 560 channels - 18,706 lights - 1 Lost Mind
    FACEBOOK: Fallatt's Charlotte Christmas
    <script language="javascript">function showhide(anc){ //
    // traverse forward from anchor to find hidable div:
    for(; ; ){ if(!anc.nextSibling) break; if(anc.nextSibling.nodeName == "DIV") break; anc = anc.nextSibling; }//
    var Y='block', N='none', det=anc.nextSibling; //
    //fall-back plan: use named div:
    if (!det) det=document.getElementById('details'); //
    //toggle visibility:
    det.style.display=(det.style.display!=N)?N:Y; //
    //prevent page refresh:
    return false;}</script><div id="details" style="display:none;">Status
    2012
    8x Ren48LSD - 100% Complete
    5x Ren 24SS - 100% Complete
    4x 7 channel Arches - 100% Complete
    FM Transmitter & 1/4 wave antenna - 100% Complete
    10x Songs - 20% Complete . . . . . . . . .
    2013
    Going DMX - 0% Complete . . . Next Year
    4x Ren-W - 0% Complete . . . Next Year
    800 Pixel Mega Tree - 0% Complete . . . Next Year
    2x RGB Wreaths - 0% Complete . . . Next Year
    . . . . . . . . . . . . . . . . 100x I'm in Trouble! . . . . . . . . . . . . . . . .</div>
    []http://joehinkle.com/HLS/HLS%20Logo%20Small.jpg[]
  4. #94
    Sep 2009
    Omaha, Ne
    1,162
    Quote Originally Posted by rfallatt View Post
    Nope. Just the PIC's are programmed. The 485 chip is just a serial line driver, no programmable logic in it.
    www.diyledexpress.com
    Backup your sequences and sync them to multiple computers with Dropbox.
  5. #95
    Nov 2010
    Charlotte NC
    442
    Am I correct in understanding that I only need to use the hex file for programming the chips with the PICkit 3
    2012
    2013
  6. #96
    Sep 2011
    Wyoming
    23
    For in circuit programming I use this from MikroeElektronika: MikroProg
    It works for PIC, dsPIC, and PIC32. It works with hex files so you can program in anything and use it to flash the PIC.
    I'm a major fan of MikroElektronika. I use their EasyPIC v7 Dev board and they're compilers for all my programming. Their compiler hardware libraries are second to none (makes USB, LCDs, and Ethernet a breeze). The compilers have a full featured free mode. Only limit is 2K words of program memory but that's enough for the vast majority of projects.
    PIC Dev Boards
    PIC32 Dev Boards
    MikroC Compiler for PIC
    MikroBasic Compiler for PIC
    MikroC Compiler for PIC32
    MikroBasic Compiler for PIC32
    /End Plug
    Last Project: Laminar Fountain
    Current Project: LightWeb ethernet lighting controller
    Next Project: Private Cyber-clone army
    Continuous Project: Convincing my wife to let me keep spending $$ on projects
