Can anyone recommend a good, inexpensive, easy-to-use PIC programmer?
Never alone
I use the PicKit2 and the programming cradle off ebay.
PicKit2 PG164120
Programming Cradle
Frank,Kiwi, I and a few others i believe are using this it works great also.
http://cgi.ebay.com/PIC-kit-2-COMPAT...QQcmdZViewItem
It comes with the zif adapter board.
I am also new (especially to PIC programming), but how about those cheaper ones on eBay like this?
http://cgi.ebay.com/Newest-Design-Mi...QQcmdZViewItem
Would those work just as well? What are the differences between the more expensive ones and the cheaper ones?
Thanks.
Hey, Macrosill - how did you hook the two of them up? Did you have to build a cable? I have the exact same combination, but never got around to connecting the two. It wasn't immediately obvious and I was in a rush, so I put the socket aside.
I will have to find it, but you can make the demo board very cheap, instructions are here somewhere, I will look for them.
So do those cheaper programmers on ebay work? Or should I shell out the money and go with a PicKit 1 or 2 ?
I haven't used either but I think the cheaper ones would work fine. Even if there were limitations you would only be out a few dollars.Originally Posted by ppohlman
TED
I bought this one and it has worked fine programming 3 REN-C's the only limitation is you can not use a USB to serial converter with it.
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
