Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 124
Thread: Simple Renard Strobe Burst
  1. #101
    Mar 2010
    Leesburg Florida
    2,490
    Default Re: Simple Renard Strobe Burst
    I think that would work. That's essentially the kind of setup I plan to test. In wireless mode, using a regular XBee module will require less current than a Pro model and leave more juice for the rest of the board but even at 12ma/channel, that 96ma total is pushing the PIC16F688 pretty hard -- that's right at the very edge of what the PIC can manage... of course, you don't have to drive the units at 100% either.... I doubt you'd notice much difference between 90% and 100% in terms of brightness and that would put your current draw on the pic down into the mid-80's... a little breathing room there...
    Hi Dave,
    that is the total current on the +5 volt supply,,, there is only about 3 to 4 ma across the PN2222a and about 9-10ma on the 5 volt supply for each strobe module,,, so 3-4ma on each channel of the PIC and 9-10ma on each strobe module is about 12-13ma total on the +5 volts
  2. #102
    Any further info about when they will be available????????????????????????????
    thanks
    Wally
  3. #103
    Mar 2010
    Leesburg Florida
    2,490
    Quote Originally Posted by wbe1 View Post
    thanks
    Wally
    There is going to be a few hundred of them ordered very soon, we had to make a small change on the PCB's, the pot was wired backwards on the first PCB's so min. and max. was reversed ...
  4. #104
    Jun 2009
    Ottawa, Ontario, Canada
    2,494
    Isn't that just a silk-screen error?
    Standard Disclaimers apply:
  5. #105
    Dec 2010
    Oceanside, CA
    2,065
    Quote Originally Posted by Mactayl View Post
    I have added code for testing to the first post if anyone wants to give it a go, it is pretty much the same code used on the Simple Renard 16 except it is setup for LED's.
    Mis-post, please delete or ignore.
    The perfect is the enemy of the good. -Voltaire
  6. #106
    Mar 2010
    Leesburg Florida
    2,490
    Not sure I ever posted some pictures of a completed Strobe Burst Module in a water tight case so here is a couple of pictures.
    They are available at http://n7xgshop.net/shop/product.php?id_product=15
  7. #107
    8,019
    Mac, could you also add a BOM and DOCs for it somewhere? They're relatively hard to find...
    dirknerkle
  8. #108
    Mar 2010
    Leesburg Florida
    2,490
    Here is the BOM for the Strobe Burst Module. I will add some info to the Wiki under Simple Renard's this week.
    Attached Files Attached Files
  9. #109
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default
    These babies rock. Especially when you have different time bases on adjacent strobes.
    Sent from my MZ601 using Tapatalk 2
    You too can become a Supporting member of DIYC.
    Check it out here
    Baulkolites.com is going to close - my new site is MyNoelLights.com
  10. #110
    Mar 2010
    Leesburg Florida
    2,490
    Quote Originally Posted by Matt_Edwards View Post
    That's how I set mine up and I also like the ability to fade them on and off at times.
    Thanks for the comment.
