Page 2 of 45 FirstFirst 123412 ... LastLast
Results 11 to 20 of 448
Thread: Finally Affortable Snowfall Tubes (FAST)
    Dec 2008
    Pensacola, FL
    895
    Default Re: Finally Affortable Snowfall Tubes (FAST)
    Quote Originally Posted by n8huntsman View Post
    Check out pages 8 and 9 of this for a good schematic and explanation of charlie-plexing. This really helped be get my head around it.
    http://downloads.eshepherdsoflight.c...d-MidiTree.pdf
    Actually, that is just an example of multiplexing, rather than Charlieplexing. With Charlieplexing, the state of each output effects the resultant selection, where in DonJ's megatree, each of 12 outputs controls a branch, while two outputs are used to select one-of-four colors for all branches.
    Charlieplexing will light (or not light) one of two LEDs (or strings) for EACH PAIR of outputs. For example, (for two outputs) If A is high and B is low, then D1 lights; if A is low and B is high, then D2 (which is wired back-to-back with D1) lights. If A and B are both high or both low, then neither D1 nor D2 light. Again, the rule is N*(N-1) lights for N outputs. In this example, 2*(2-1)=2. The advantage comes when you build up the number of outputs feeding the matrix.
    However, as you increase, you lose discrete control, unless you can tri-state (open-circuit) the outputs. Lacking that capability, for 8 bits of data, you can control 8*(8-1)=56 lights. Since there are 256 possible states (ON or OFF) of 8 bits, there are only two states with all lights off (00000000 and 11111111). All other bit patterns will result in 7, 12, 15, or 16 lights on. Actually 7 occurs 16 times, 12 occurs 56 times, 15 occurs 112 times, and 16 occurs 70 times. Each light is on in 64 of the 256 states.
    (Isn't matrix math fun????) :roll: :roll: :roll: :roll:
    As usual, I've gone on way too long, but that's me... (see my signature):D
    Longfellow said that in this world a man must be either anvil or hammer.
    But some are neither, they are merely bellows.
    2,147
    Quote Originally Posted by WireWrap View Post
    Also, by adding bipolar transistors across the resistors, you can increase the I/O pin drive capability so that you can turn on multiple LEDs within a "row" of LEDs without burning out the I/O pin. An EDN article about "chipiplexing" a while back described that trick.
    don
    Click for display details >>
    Apple Valley, MN
    3,755
    Of coarse as you know, using an appropriate optocoupler will allow you to drive nearly anything you want.
    </div>
    2,147
    I was thinking that optocouplers are used more for voltage isolation, but that's an interesting idea to use them for current protection purposes also. thanks.
    don
    California
    2,512
    pretty neat
    [B][I]MY Favorite Links:[/I][/B]
    [URL="http://doityourselfchristmas.com/wiki/index.php?title=Main_Page"][COLOR="red"]Christmas Wiki[/COLOR][/URL] | [URL="https://www.facebook.com/dancingofthelights"][COLOR="red"]My Facebook Page[/COLOR][/URL] | [URL="https://www.calvertimage.com"][COLOR="red"]My Website[/COLOR][/URL]
    [B]2013 Show[/B]
    1 - E682 not in use
    248 - Renardss Dimmable channels
    144 - Renard48lsd channels
    272 - channels in use
    40,000 lights synchronized and static
    50% assembled and displayed
    Cape Coral, FL
    1,072
    Ok, I got my LED's in from the group buy and away I go.. Here are some pics of my first one.. Being that I'm lazy and cheap I didn't feel like going to the store and getting any formica to start this project. I had an old screen out of an old rear projection tv in my garage. The diffuser on the front of the fresnel lens has nice groves in it perfectly positioned to run a razor blade down it to score it and snap to the width I wanted. The screen I'm using happens to be around 24" tall If I want different size tubes I just find larger screens. People are always throwing these TV's away now what I nice way to recycle part of them. On a side note the Fresnel lens is very fun to play with but very dangerous. WARNING : It'll make a spot and get it 2000+ degrees.. You can melt glass and or steal or give yourself a nice sunburn.. So here are some pictures of what I've completed so far.. Not pretty but functional and the screen was free.
    May 2009
    Murrieta Ca
    392
    Looks great so far. Hope to see the finished product by monday, and of course we will need video of it actually working so we can all want to do it.
    tweist
    736 Channels
    65+ Wireless Ren controllers
    [COLOR="#0000FF"](2013) 25+ houses[/COLOR]
    (2012) 20 houses total
    (2011) 13 houses total
    2012 video
    [url]https://www.youtube.com/watch?v=_KVM_EPKYMM[/url]
    2,192
    Quote Originally Posted by tweist View Post
    +1
    \dmc
    S.E. Wisconsin
    20
    Hi, trying to follow along with the schem.
    All the LEDs in both drawngs are labled D?
    Although the color "wiring"diagram helps, still not sure what sequence to wire the LEDs.
    Oh, btw, I am planning on using 3/4" green plastic Banding tape we use at work. We throw thousands of scrap pieces away daily...
    If anybody wants to try ths flexible pcb, pm me
    Master Electrician/ Electrical Inspector/ Evil Genius (apprentice)
    .....I know NOTHING, and prove it daily !
    Getting crazy ideas and breaking stuff since 1977.
    Ontario, Canada
    2,134
    Hi all, been semi-away for a bit.
    I just came back from Home Depot after my weekly drool-fest in the store.
    Flourescent tube covers.. about 2 bucks each and up to 4 feet long. They are clear and have caps on each end with an opening to allow the prongs to poke through.
    Use those and a small pcb board for the hardware and run a ribbon-cable (or even a pair of cat5 cables) off the board and the leds soldered to the ribbon. a small elastic band keeping the ribbon cable taunt at the bottom, in the same fashion as the di-pole antenna tensioner.
    Could not find a HD sku number online, but here is a UK store with the same items..
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
