dirknerkle
If you are shopping for coroplast search for sign supply shops and not sign shops. I bought from sign supply usa which is an outfit that sells to sign stores. They have locations all over the US. You might try using google with "sign supply" and the name of your city or state. Even if they say wholesale only there is no penalty for asking. I think I paid around $12 for a 4x8 sheet, but that was 3 yrs ago. They even have it in colors and different thichnesses. I got lucky with a warehouse only a mile from my house.
Jim Nealand
Kennesaw, Ga
If you do not mind a little clean up, the local bus company is a good stop. I can get the old advertising signs that are mounted to the bus for free. Usualy needs the sign peeled off and then cleaned. Great for short and wide type projects like a "Merry Christmas" sign.
[QUOTE=boyelroy11;157048]Dave- I tried to find example pictures of how I mounted my stuff, and these were the best two I could find. You can see the pcv frame I made for the angel choir, and in the second pic, you can see the zip tie loops, two in the middle, going to the pcv stem, and one in a lower corner to prevent rotation.
Thank you! I have been wondering how I was going to mount some home-made snowflakes on my roof - your pvc rig seems like a perfect solution. I'll probably double-up the uprights so I can fasten both sides of the coro.
BTW, I got some 4'x8' sheets from my local sign shop for $15 ea.
Have to thank Bruce for the Regal Plastics tip.
Wife had a doctors appt so I tagged along and we went to DesMoines.
4x8 sheets of clear were only 9.92 each.
They only had 4 sheets so I took them all.
Add tax and order processing charge, I got 4 sheets for 50.01
If you have a location near you, this has to be your best option.
http://www.regalplastic.com/locations.html
Thanks again Bruce.
Joel
If I no longer count channels... but instead say I have over 12 universes... Is that too many
Glad to help out! Nice to give back when possible.
Bruce
