Would you mind posting the idea you have in mind for you coro?
Check your local industrial plastic suppliers- I get mine through the local branch of Regal Plastic: http://www.regalplastic.com/ 4x8 sheets of 4mm thick under $20 and 10mm thick under $30.
HTH
Bruce
How do you all secure coroplast from the wind? Sometimes our winter storms come not only with snow but with 30-50mph winds. I tried a couple relatively small signs with it over the past two years and each time, they've either broken or blown away. It's kind of neat stuff, but I haven't figured out how to mount it securely enough yet.
dirknerkle
Yeah, we hit the Henry Doorly up there once a year also, not to mention the old market and the trains in the botanical gardens.
Dave- I make pvc frames for everything, then do small holes (usually with a phillips screwdriver or drill) and use zip ties to affix the coroplast to the frames. I did a rack of angels on the roof, a Linus cutout and 20 snowflakes this year without a failure. We had some 40mph gusts in one storm and they stayed put.
Bruce
All my coro items were purchased through www.holidaycoro.com I have used David's coro trees (10 of them last year) along with a full 4x4' talking rudolf, tune-to sign and dim headlights sign. I was very pleased with the durability and quality of his products.
Dave- I tried to find example pictures of how I mounted my stuff, and these were the best two I could find. You can see the pcv frame I made for the angel choir, and in the second pic, you can see the zip tie loops, two in the middle, going to the pcv stem, and one in a lower corner to prevent rotation.
IMAG0064.jpg angel rack
IMAG0078.jpg mounted
Bruce
dirknerkle
For 4mm coro you really can only use 9ga wire - it's just large enough to "grab" onto the interior of the flutes but not be too large as to damage the flute - a good friction fit. 9ga is also strong enough to prevent bending (you'll need the neccessary amount depending on the overall size). I'd look for "H" frame stakes for standard coroplast signs.
That is an excellent solution - it looks like the PVC is flexible enough (like a tree is) but still stiff enought to hold up the design.
