Results 11 to 20 of 21
Thread: Storage containers
    Apple Valley, MN
    3,220
    Default Re: Storage containers
    I feel good now, I'm better than a brain dead monkey.:p
    On the brain dead monkey scale of soldering, you actually rank 'Super Human' Ern.... :D
    Wait... That doesn't sound right
    -Mike
    www.LandoLights.com
    www.SequenceCenter.com --> Vixen/LOR Sequences and More
    Avon Lake, OH
    479
    Thanks for the pictures. I want to be organized, and figured I would ask those who have been there before.
    Erik
    Feb 2011
    Eagle Point, Oregon
    405
    These organization schemes have some important hallmarks of Lean Manufacturing that really do make a difference and reduce errors:
    1. Label the bins with pictures to aid visual recognition
    2. Label the bins with process steps
    3. Label the bins with quantity used per part and a min/max stock limit.
    4. Put the bins at the point of use so you don't have to waste time traveling back and forth
    These actions improve efficiency, but they also reduce errors because they are more easily recognizable visually as opposed to reading a bunch of text. You can see the effect when you walk up for the first time and take a look at what's going on. In the first example of the bins, you can see what parts are needed, when they're used, and if you are out of stock. This without having to ask any questions! Hence, the brain cells are able to focus on other things.
    Nice work guys and a great example for me to begin organizing in anticipation of the arrival of my group buy stuff!
    Yuma, AZ
    1,466
    Hi:
    I went to Home Depot today and purchased one of the parts bins. You guys shamed me into it. No more Christmas out of my cardboard box. DARN!
    Idun
    Lotsa' Patience! (Some days you can't win, the others you lose, and forget about the rest)
    Some mornings I wake up GRUMPY and other days I let her sleep!
    Knoxville, TN
    183
    Quote Originally Posted by IdunBenhad View Post
    Hi:
    LOL Idun. I didn't see anything wrong with your set up. I can tell you this, there's more organization there than I currently have. The first step for me when it comes time to build my boards is going to have to be clean up my bench. Besides, who doesn't like Christmas every day?
    Brian
    Where was I when all this took place?
    Yuma, AZ
    1,466
    Hi:
    Well, I had to clean up my bench to find a place to put the parts bin. Then, being the organized, orderly guy I am, I printed labels for all the bins and started to apply them.
    Guess what! My labels were so old, they wouldn't stick on the bin, so I started using Scotch tape to apply them and I ran out of tape! I have about half the bins to go.
    Maybe I'll just throw everything back in the box and give the parts bin to Grumpy for her sewing. Except she might sew my wallet shut.
    The only problem with that is I put the box in the trash today. Trash man said I should be recycling, but I'm not a little green man. I'm going to bed.
    Idun
    8,038
    I bought about 4 dozen 6-quart plastic container bins from Target -- they were about $1 each (on sale) with a snap-on cover. Each is labeled with the "stuff" that's inside, such as "RESISTORS" or "DIODES & CAPACITORS", etc. and I put them on a bookshelf (photo attached).
    With parts from Mouser (or elsewhere) I just leave them inside the anti-static bag, but I relabel it with a marking pen because the thermal labels always fade. For instance, packs of resistors are just standing in packs in ascending order by resistor value. Capacitors are much the same. With the covers, everything stays nice and neat inside and in order. When I build something, I just go from one bin to the next, selecting the parts I need and putting the bags back inside in order again. It's turned out to be a pretty efficient system for me and I can usually find things quite quickly. Bins are categorized as follows (in no particular order):
    Triacs/Dip sockets/Fuses/Terminal blocks
    Cat5 plugs/jacks/crimper/tester
    Capacitors & Diodes
    PIC Programmers & PICS
    Resistors
    LEDS & Transistors
    Wi-Fi Antennas
    FM Transmitters
    Plugs/Heaters
    Prototypes/Bare Boards
    XBee/Ren-W
    Prototyping Boards/Supplies
    Cable Testers/Meters/Kill-a-Watt
    Cable Converters/Adapters
    Audio/batteries/battery holders
    Video/webcams/connectors
    SSRs/
    PC Gear/Serial Converters
    DMX Gear
    Extra Mini-Lites/Fuses
    Light clips/color caps
    Production PCBs
    Copper Boards
    Misc Electronic Parts/Regulators
    Misc Hardware/screws/nuts
    Cabling supplies/heatshrink/tape
    Crydom Triacs/High-Power switches
    Timers
    X-10/Wireless Switches
    LED Projects
    Olsen595/Grinch/Parallell
    K8055 boards/USB Hub
    Ren-C/RenSS/LV/Ren64
    MiniRen8/4 - MiniRen8/8
    Ren816/Ren816XB
    DC Wall Warts
    AC Wall Warts
    dirknerkle
    Tampa, Florida
    137
    Don't know if you remember Mike (oldcqr), but my wife and I visited you as my first experience to this whole addiction, we live north of you in Dade CIty ... this past December. When you showed us your back building with all your stuff, it was the organization that impressed my wife. Little did I know then having never seen a setup of lights before that I would catch the fever like I have (and haven't even set up a single light yet). Seeing the pictures of Dirknerkle and james70818 storage methods remeinded me of your bins being used for storage.
    I guess the next step is going to Home Depot and buy some storage containers now that I have alot of group buys under my belt and have ALOT of PCB's and BOM's coming my way soon.
    PS the wife is not going to be involved, but is "letting" get into this "hobby" 150%.
    PPS am I way too much into the sequencing phase when I see orange traffic cones lined up bay a road and it reminds me of a mega tree sequence?
    Going to Plan D
    Controllers - Ready to go.
    Lights - Need to buy more !
    Sequencing - Work in progress.
    GOALS:
    2011 First year as many channels as time allows
    I remember.... She had that 'he's taking us into the woods to kill us' look on her face
    It's actually a LOT more organized when it's not the middle of the season. You should see what it looks like right now.
    Organization will set you free.
    -Mike
    www.LandoLights.com
