Results 1 to 10 of 11
Thread: Help with rope light
    Phoenix Az
    94
    Default Help with rope light
    After finding as much info as I could, I have started building rope light arches. I have segmented them successfully, and can get power to them, but it is not a very good connection. The only thing I haven't tried is tinning the ends before inserting them. Anyone have any tips?
    128 channels
    2 rope light leaping arches
    2 houses controlled
    2 Singing garage door
    Spencer Iowa
    1,084
    Default Re: Help with rope light
    If I no longer count channels... but instead say I have over 12 universes... Is that too many
    Treasure Valley, Idaho
    2,314
    Quote Originally Posted by alanf View Post
    I strip the wire back about 1/2" and tin it. Then I cut about 1/16th off at about a 45 deg angle. That leaves kind of a sharp end to be able to stick in. I use a fairly small nail to poke a hole in the end of the rope light right next to one of the main leads. Pull out the nail and insert the tinned wire. Repeat on the other wire then test your connection. I cover the junction with clear shrinkwrap and heat. Seems to give a solid connection that is very stable.
    South Sioux City, NE
    108
    I strip the wire back and solder the power cord to the rope light and wrap in heat shrink and electrical tape, haven't had one problem with it.
    Plainview, Mn
    1,073
    I use small Brass Brads and just solder them to the end of the power cord. I just insert the brad into the wire channel and dab a little clear liquid electrial tape on them. Never had a problem.
    HA, somebody else is putting up my lights this year.
    California
    1,522
    well if using copper wire soldering the wire to the rope light should be a lot easier since copper absorbs the solder easily so tin the wire end then solder the wire to the rope light while adding a little more solder then it should bond a little better
    DIYC Links:
    Christmas Wiki | New Posts | Chat Room
    Certified Electrician
    248 Dimmable channels
    100,000 lights~increasing everyday
    35,000 lights subject for holiday display
    Phoenix Az
    94
    Thanks tining the ends really helped
    128 channels
    2 houses controlled
    Jan 2010
    Mims, Fl
    172
    i need to add cords to my rope light star. I get the tinning and/or brad nails. My question is the heat shrink. Is there a better kind that will fit around the rope light and shrink enough to grab the SP-2 cord? i can't imagine it will shrink that much. Maybe possibly doubling the cord back onto itself? i need to check the link above, but it is blocked here at work (of course i am on break!)
    i was going to silicon the area an slide the heatshrink over that, an add more silicon inside the heatshrinkt just before i start it shrinking, so it makes a perfect water tight seal
    2012 Checklist:
    7x mini floods
    2 RGB 9Ch Led Leaping Arch - 630Leds, 9 channels per colour - 27ch's each
    Mega Tree 5m - 14x r g b w leds - 54ch's
    10x RGB CoroStars - 6 RGB 5050 Leds in each - 3ch
    1x RGB Merry Christmas Sign
    - 42ch's
    2x 3section RGB Coro VU Meters - 27ch's each
    RGB Led Mega Star - 24ch's, 3ch each point of star
    10x Ledancer tubes
    150x ACL Led Strobes
    1x RGB Coroflake
    http://www.youtube.com/watch?v=bH7gDBDrFok
    Sep 2008
    Baulkham Hills, NSW
    2,241
    I too use the tinned wire method.
    Similar to what Alec to saying I do the following:
    For 1/2" rope light, I use 5/8 thin walled heat shrink, cut to 1 3/4" lengths
    I smear a little silicon on the last 1/2" section of he rope light
    Place the heat shrink on the rope light and shrink only the portion that covers the rope light.
    Now stick the silicon nozzle into the other end of the heat shrink and give it real good squeeze
    Carefully shrink the remainder of the tube.
    You will soon learn if you have added too much silicon;)
