Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Schedule Error: Object reference not set to instance object
    Tampa, FL
    110
    Default
    KC I know your very busy. I was wondering if you were able to recreate the problem and if so what caused it? Ever since I did what I said in the last post everything is working great.
    Long Island, NY
    7,656
    Default
    Guys, Make sure you enable "Hold Port Open" in the Renard Serial setup. I was having the same issues and that simple step solved them all.
    In addition to that I am using Phil's modified Renard plug in, did a fresh install and made new sequences instead of using the converted ones.
    see this thread http://www.doityourselfchristmas.com...pic.php?t=1682
    Tampa, FL
    110
    Default
    Brian I think our issues are different. I didn't have hold port open checked before or now and I'm not having any problems now that I resequenced that particular song. I used the same profile as before just a new sequence file. Actully holding the port open caused errors that the port was in use.
    Long Island, NY
    7,656
    Default
    I was just going by the description in the OP.
    70
    Default Re: Schedule Error: Object reference not set to instance object
    Did this issue ever get resolved? I am having the same problem with one system. Must have "leave port open" un-checked or crashes with port error. Get this object error on occasion (sometimes it runs for hours with no crash - other times it will crash in less than one hour). After clicking OK it continues - but what if I am not home to do that?
