DIYC Links:
Christmas Wiki | New Posts | Chat Room
Certified Electrician
248 Dimmable channels
100,000 lights~increasing everyday
35,000 lights subject for holiday display
Ok picture story on how I did it. Its lots of big pictures with few words
(One thing I forgot to add to this . If you are planning on controlling any LEDs with DCSSR's make sure you buy common anode type . )
This is how my SMD strip showed up from China it came with the little remote etc. I played with them for about 3 minutes just to amuse myself and to test that the whole 5 mtr strip worked.
My Ren64XC test board + my 240/110Vac to 12VDC 30Amp switch mode power supply Therotically this can rum 30mtrs of SMD strip. But I only plan on running my arches on this one. Should be pulling a max of 14 - 15 amps with my mini arches + a DCSSR to run off the Ren64XC
The clear conduit sitting in the sun trying to get the kink I accidently put in it out. Its a Clipsal product http://www.clipsal.com.au/trade/down...g_and_fittings its in the Non Metallic Cable Enclosures & Fittings Technical Data, 892-941 catalogue
The translucent tubing I covered my conduit with, I ran a test tonight with and without , with looks heaps better in my opinion.
On to the business end. I worked out with ground clearance I need 3.6 mtrs of light with 6 channels per arch. So time to cut that nice new strip up into 600mm lengths. I was going to tap into the strip but figured if I have an outage its easier to replace a section then rewire a whole strip.
Once I had all my strips I turned them over and used my dremel with a sanding drum to clean off all the sticky bits off and get a nice clean solder point on each strip.
My choice of wire good old 2 paired telephone cable. At $23.00 / 100 mtr roll its cheap and it just happens to match closely to RGB colors . I substitute Black for Green Channel and White I use as the common.
Disgusting solder joints here . But Im still getting used to my new soldering iron. Shows wires solder to SMD strip though and it did test ok suprisingly. I use a 3.6mtr piece of wood to work out how long the wire needs to be . I place the SMD in its position then allow the length of the tube from its position plus however many mtrs of wire I need protruding to reach what will be my SSR box.
Once all my wires are soldered on I attach the smd to good old fashioned packing strap to give it a backbone. Again to retain replacability I just use lots of insulation tape to tape the smd, cable and strapping together.
One 6 channel strip ready to be inserted unto the conduit.
2012 Plans
1 Pixel Megatree (Finished)
20 x 3D Mini Trees
40 x Mini Roof Stars (Finished)
Columns (Qty to be decided)
Pixels Pixels Pixels
2011
3 x RGB arches
6 x RGB Window Display Trees
2 x RGB Window Display Bells
6 x RGb Window stars
5 X Mini arches RGB
1 x RGB Bethlehem Star
14metres of Eave Lights
Part 2 Sorry its gonna read backwards now .
Using a holesaw I drilled a hole 200mm from the end of my conduit on the backside of the arch . My first one I did it on the inside of the arc and the conduit cracked and wouldnt hold its shape.
I then inserted the conduit into my tubing and cut out the hole for my wiring. On future arches Im just going to make the tubing reach the holes as I ended up cutting everything below the hole off anyway once I made my mounting stakes (Pic later)
Time to insert the smd strip I taped on a 4mtr length of wire with a weight on the end to make it slide through easier . Just hold the conduit up and shake .
Once all the way through , I retrieved my cables through my hole in the back. I tried to keep the smd strip facing up as much as possible . With the tubing on it I found it doesnt really make much difference to the overall effect though.
I originally slid the conduit over a piece of pipe. But ended up making these from 32mm conduit. I just cut a point on one end and belted into the ground. The 25mm clear conduit fits snuggly inside these.
Finished product prior to change in mounting style.
My test relay board . Power in is from the switch mode power supply . All SSR's are DCSSR's from wjohn
Took a new video of this again tonight with a video camera not much better but I slowed down the sequencing a bit to get a better idea of what it looks like.
Oh and no its not your eyes there is a second arch beside it but I had a bad connection on channel 5 and its not covered with tubing yet.I was just testing it
http://www.youtube.com/watch?v=gu3kJfccniU
Hope this answers all your questions
2012 Plans
20 x 3D Mini Trees
2011
3 x RGB arches
5 X Mini arches RGB
I must say they are very nice and well constructed.
The how to and pictures are well done, great job..;)
+1 on that - nice job!
Brian
Halloween in San Jose! - FB
2013 Halloween Show - Homemade tombstones, Grave Crawler, 2x 3-axis skulls, 4x 1-axis skulls, Video Projection
DIYC Links:
