Results 1 to 6 of 6
Thread: Anyone have parts for Kostyun DMX Servo and Mighty Mini
    Nov 2010
    Livermore, CA
    1,000
    Default Anyone have parts for Kostyun DMX Servo and Mighty Mini
    Kostyun's site is pretty beat up with no real information on assembly downloadable BOM lists etc.
    But I was able to cut and past and for the servo Mouser is backordered on a lot of parts, so figured if someone had some parts.
    Also does anyone have the instructions for the mighty mini and maybe a bom or parts list? (also any updated build to help with some of the blow outs that would be nice).
    Tory
    Just south of Portland Oregon
    794
    Default Re: Anyone have parts for Kostyun DMX Servo and Mighty Mini
    No servo info but here is a link to the MM instructions:
    http://www.kostyun.com/PDF/building_mighty_mini.pdf
    I purchased my LED's from C LED or something like that and they sent resistors. There was some discussion about burning out LEDs so I changed the values of some of the resistors based on current measurements.
    While the stock resistors allow about .95 - I modified to run in the .80 - .87 range.
    I lost your email address, PM me the info and I'll send you my current draw data - ya, it's the current data too.
    Greg
    Found it (LEDs)
    http://c-leds.com/store/product.php?id_product=42
    Long Island
    460
    check out the posts on using LM317's for constant current in the mminis. A little more expensive to build that way, but a better finished product.
    The resistors from c-leds have never been right. I got my leds from shop4leds on ebay.
    2009 (2) Ren SS24, (1) Ren 24LV, 3 Mminis
    2010 (3) Ren SS24, (3) Ren 24LV, (6) Mminis, (12) SSRez, (13) Super Strips RGB+W, (8) Super Strips UV+W, (2) Ren 48LSD, RPM DMX
    2011 Adding (50) AussiePhil strobes, Pixel strings looking tempting
    Nov 2010
    Livermore, CA
    1,000
    Quote Originally Posted by DIY Guy View Post
    I've read 2 or 3 threads and none of them gave me a warm fuzzy that this fixes the issues that people are citing.
    This stuff is over my head..
    And Greg people cite that C-leds shipped cheap resistors with their LED's.
    UUGH learning curve on some of this stuff is sharp
    Tory
    Long Island
    460
    I haven't read anything about the LM317 other than good results. I have 3 mighty minis running with resistors (at about 95-104mA) and 3 with LM317 (I used a 13.2 ohm 1% resistor, don't remember what that limits current to).
    Both have worked fine for me. I do believe that many of the issues were due to the wrong resistors in the original BOM, and then the wrong resistors being consistently shipped by c-leds.
    Whether you choose resistors or constant current, I think you're fine as long as you do the math for yourself.
    I have a blog post that is pretty good if you want to use resistors. There is a thread with a PDF build guide for constant current-- also very good.
    Jan 2010
    Nashville, TN
    750
    I've got four MM's equipped with LM317's that work great, and I've already bought housings to make four more, soon as I see a decent deal on LED's. From personal observation/experimentation, unless you have some rock solid LED's that you know won't go into thermal runaway, I'd choose the LM317's (or some other form of a constant current device) over resistors only every time. FWIW, I ran my MM's every night for 4 -5 hours for the month of October, and am running them 4-6 hours a night for the month of December, and haven't lost a LED yet (knock on wood).
    208 channels
    2 Ren 24SS / 4 REN 16SS / 2 REN 48LSD controllers
    8 Mighty Mini RGBW floods
    1 LEDTriks
    2 Helix V3 controllers and Vixen to rule them all
