Results 1 to 5 of 5
Thread: help with Parallel testing for hill 320?
    Raymore, MO
    129
    Default help with Parallel testing for hill 320?
    My hill 320 isn't working as intended, and I'm trying to figure out if the right signals are coming from my parallel port. So far, I've tried setting different PPT modes in the bios, but I get the same output (pins 2,3,4 and 9 =5v and pins 5-8 = 0v)
    when I check each channel on my controler, Some are always on, and some are always off.
    sometimes I get some channels switching in sync with the vixen sequence playing for a short while, then it goes to the above mentioned senario.
    Is this maybe a clock issue? How do I check the clock?
    I've also checked the data pins at the parallel port (without controller attached), and every time I've done it, I just see the output above. Is this a normal to only see it like this? Do the signals just switch too fast to be able to detect on an analog volt-meter?
    Also, I get exactly what I expect when I set vixen to use a standard parallel port output (8 channel), and probe the ppt port directly.
    I'm completely lost at this point.
    thanks for your help.
    Virginia Beach, VA
    1,204
    Default Re: help with Parallel testing for hill 320?
    Check your cables and connections look for anything that would allow any electrical noise to be picked up by your cable.
    More channels then I can use.
    More light bulbs then I care count.
    http://www.vimeo.com/user1106747/videos
    Raymore, MO
    129
    Quote Originally Posted by RichF View Post
    Nothing looks obvious, but I am curious if the problem is before my controller anyway. When using the hill320 plugin with vixen, should I be able to probe the parallel port directly on the computer.
    Raymore, MO
    129
    Found my problem...melting insulation (from soldering heat) on a couple of data connections to / from the Hill320 (improper selection of wiring to use - CAT6)
    My name is a158946, but my friends call me Mike http://www.mikeandbobby.com
    2011: 7 songs, 3 Ren64s (3rd just for placement), 108 Channels, 10873 Lights
    2012: 7 songs, 2 Ren64s, 2 RenSS24s, 147 Channels, 11887 Lights...Parents also showing early CLAP symptoms (muhuhahahaha)
    Jan 2011
    spartanburg, sc usa
    1
    I have a question about the HILL 320. Do you use capacitors on the 74ac574pc chips? If so, what kind are supposed to be used? This may be the wrong place to post, just thought that someone here would know.
    thanks
