Results 1 to 10 of 13
Thread: REN-C PIC HEX file
    Oct 2009
    Bennington, NH
    82
    Default REN-C PIC HEX file
    Dose anyone have the REN-C HEX file. i tried to make it but it dosent operate. I'm new at the RENARD boards and am tring to get my OLSEN
    595 to dim. Right now its not doing anything
    P.S. dose it operate at the 56000 baud rate to?
    Joe O'Brien
    2009 - 1- Olsen 595 running 40 channels
    :D
    2010 1 Olsen w/64 Channels & Ren-c
    1 ren 24, 2 ren 8's, (hopefully)
    2011 2 Olsen w/64 Channels, Ren-c & Ren-t
    2 Ren SS24's, 2 Ren SS8's
    Complete New Layout
    Nov 2008
    Dewitt, Michigan
    88
    Default Re: REN-C PIC HEX file
    Go to :
    doityourselfchristmas.com/wiki page
    click on Electronics Hardware
    then to the Renard link
    then the Renard-595 converter link
    then find the link to take you to the Firmware.
    There is lots of information on what you want to do with the 595 converter there....
    Hope this helps
    Virginia Beach, VA
    1,204
    YEs runs at 57600
    If you need the firmware let me know I have both the published and a beta version in HEX format
    More channels then I can use.
    More light bulbs then I care count.
    http://www.vimeo.com/user1106747/videos
    Oct 2009
    Bennington, NH
    82
    Red face Re: REN-C PIC HEX file
    I found my problem. i forgot to install the J1 jumper on the Olsen595 board. all works now
    Joe O'Brien
    :D
    Complete New Layout
    Dec 2010
    Crab Orchard, NE
    596
    I know this is bringing an old post alive but didn't want to start a new one since this one was there.
    I'm trying to build a .Hex for the REN C but cannot get it to build from the wiki asm. Looking for help. This is what I get when I try to build
    Clean: Deleting intermediary and output files.
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F627A "Renard-595-192-20090505a.asm" /l"Renard-595-192-20090505a.lst" /e"Renard-595-192-20090505a.err" /o"Renard-595-192-20090505a.o"
    Error[113] C:\USERS\ZYLA FAMILY\DESKTOP\RENARD-595-192-20090505A.ASM 90 : Symbol not previously defined (_DATA_CP_OFF)
    Skipping link step. Not all sources built successfully.
    If anyone can help me that would be great... Or if someone would happen to have the .hex already and could post that would be great.. Please let me know
    "I have to plug ALL of these into what??"
    Find us on Facebook
    Crab Orchard Christmas
    30,000 lights and counting
    8,021
    Try this one instead.
    Attached Files Attached Files
    dirknerkle
    Dec 2010
    Crab Orchard, NE
    596
    I'm not sure what I'm doing wrong but I'm getting the same error with that one as well Dirk. I've used MPLAB IDE project wizard as well as tried manually.. can't get it past that point. The only thing that changes is the 20090505 turns into 20090506. I've entered the pic, not sure what I'm doing wrong.
    I dunno..
    Find us on Facebook
    Jun 2007
    Ft. Walton Beach, FL
    1,501
    It appears that there is something wrong with the include file or it is missing.
    _DATA_CP_OFF is defined in the include file.
    Check to make sure the file: p16f627a.inc is MPASM Suite directory
    What version of MPLAB IDE are you using?
    RavingLunatic
    Not just a username but a state of mind
    Dec 2010
    Crab Orchard, NE
    596
    I'm using v8.63
    I'll be honest.. not sure I know what I'm looking for.. this I'm absolutly lost on
    Find us on Facebook
    Jun 2007
    1,501
    OK, I installed that version and the p16f627a.inc (released with MPLAB IDE Ver. 8.63) file had that symbol defined a little different:
    change _DATA_CP_OFF to DATA_CP_OFF
    In case you cannot find it, the line looks like this:
    __CONFIG _CP_OFF & _DATA_CP_OFF &_LVP_OFF & _BOREN_ON &_MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
    change to:
    __CONFIG _CP_OFF & DATA_CP_OFF &_LVP_OFF & _BOREN_ON &_MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
    RavingLunatic
