Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Generic Serial Help
    7,868
    Default Re: Generic Serial Help
    Quote Originally Posted by scott130377 View Post
    Hi, if mheuer reads this is there any chance of posting the .zip file again as the link above does not work.
    Here's the Wiki link: http://www.doityourselfchristmas.com...in_Development
    (for most of these link breakages replace christmasinshirley with doityourselfchristmas...
    Brian
    Halloween in San Jose! - FB
    2013 Halloween Show - Homemade tombstones, Grave Crawler, 2x 3-axis skulls, 4x 1-axis skulls, Video Projection
    hello
    I would ask that someone showed me how to look like the data frame sent by the plugin "generic serial", I want to steer through the Vixen -> uC-> triac output.
    Thank you;)
    Jul 2009
    Kansas City, KS
    182
    Hello,
    Sorry I didn't respond sooner, here's the plug-in attached below.
    Attached Files Attached Files
    Apr 2012
    Central Coast, NSW, Australia
    6
    Sorry to bump an old thread - I was wondering... I found an issue with the Generic Serial output plugin... a limitation to the number of com ports... I saw in the forum here the plugin are open source... is there an issue with making changes to the original code to allow more than 4 ports? Would KC mind if I made a new dll from his generic serial code lifting the limit from 4 to 32 ports?
    Nov 2010
    Melbourne, Australia
    46
    Quote Originally Posted by tsargeant View Post
    This whole hobby is about sharing so by you modifying it to add something extra to it, the only thing you'll make people is happy ;)
    Apr 2012
    6
    Well I have a shiny new dll... it's the generic serial output plugin... that now allows 32 com ports... tested with a teensy ++2 (USB) on Com18... it works without a prob.
    Nov 2010
    46
    Maybe you just need to post the DLL now for others
    Apr 2012
    6
    I posted a quick "How to" for the Teensy ++2 board - I've included a zip file (Teensy.zip) in the post that contains the dll and a basic Arduino sketch that will get the teensy working...
    http://doityourselfchristmas.com/for...ow-to-Teensy-2
    Hope the dll helps with anyone else using multiple serial ports
