Results 1 to 6 of 6
Thread: routine to shut off lights
    Aug 2007
    Salmon, Idaho
    184
    Default routine to shut off lights
    I recall last year there was a "routine" that made Vixen keep all the lights off after the show is over and computer is still running in stand by mode until the next night.
    I believe KC wrote such a routine but how to obtain it??
    Mooresville, NC
    7,589
    Default
    Yes, it is a background script. You only need it if you are using a 595 setup.
    Here is a good read... and there is more just look for 'scripted sequence' in the titles.
    http://www.doityourselfchristmas.com...pic.php?t=1332
    Aug 2007
    Salmon, Idaho
    184
    Default yes I have a 595 to run
    I copied this from your post
    void Start() {
    Off(All, Every(30).Seconds);
    WaitOnTimers();
    now what do I do with it????
    Anthem, AZ
    77
    Default
    I had to do the same thing - here is how I did it.
    First Select - Sequence | New Event Sequence | Vixen Script Project - this will open to the script editor.
    Enter the script - it should now look like this.
    void Start() {
    WaitOnTimers();
    Now you need to import your channel list.
    Select - Script | Import Channels | Now select a sequence that has the channel list you want to use. I picked my test sequence configured with 128 channels.
    Pick the plugin and map it - Select - Script | Attached Plugins | Now pick and configure your Olsen 595 - just like you did for your regular sequence.
    Select a module - Script | Modules - And Check Standard.dll
    Now press F6 to compile
    This next part - I don't know if I did right - but it seemed to work.
    Save as - and I entered the name - All Off Script
    Then it asked me again to save as - and I enter All Off Script - again.... I don't know why it asked twice.
    Then I selected - Sequence | Set Background Sequence | Select - and selected the file I just made - All Off Script
    When I tested to see if it was working - at first it did not. I found that under the - Tool | Preferences menu I needed to check the Enable Background Sequence box under Background Items.
    That seemed to make it happen.
    Mooresville, NC
    7,589
    Default
    If it is working, there will be a small scrolling bar in the bottom left of the Vixen main window. ;)
    Ontario, Canada
    2,131
    Default
    My apologies on hijacking the Thread..
    I followed the walkthrough as written above, I have my bottom left scrolling indicator suggesting its working.
    My channels all flash on after 4 seconds after the sequence stops, and remain on until I force them off manually or restart the sequence.
    I've replaced all my Allegro's, double checked all my solder joints, cables are all 6 feet or less for this test and all are working. All grounding points are good, started with a clean Vixen install and scripted a simple 4 channel sequence with music to test with. Regulated 5VDC 500ma power supply. And lastly tried all 32 of my SSROZ's with the same results.
    Any suggestions?
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
