Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Led Spacing
    Waterboro Maine
    1,020
    Default
    3/4 is the max you can go without buswire
    and yes all the leds should be facing the same way
    Sacramento, CA
    353
    Default
    Quote Originally Posted by wjohn
    Matt,
    1/2 spacing allows you to use the LED legs and just bend them in tohe direction required.
    I am going with 15mm (2/3) inch for the same reason.
    John.
    Thought about that, but I would have to drill
    However seems like at this point drilling would be quicker then adding bus wire. I mocked up a pannel with 32 leds on the 1" board. It was a MAJOR pain! I have cut the peg board and painted it. So I should have measured twice and cut once. Oppps.
    I built a mini 32 LED board on a board with solder pads, that was real quick and easy. Did this just to test my boards. It has created a couple questions that I will be posting shortly.
    ms
    ms
    Matt Stemple
    Sacramento, CA
    353
    Default Spacing Template / Drill technique?
    Since I can't find board pre drilled to 3/4" or 15mm (both suggested hole spacing) has anyone created a template that can be printed and used for the whole spacing pattern?
    I am going to get some un drilled mdf sheets and do 3/4" or less spacing but don't have a jig setup to get the spacing right, so a paper pattern would work. If you have done this and have such a pattern please let me know before I start making my own. Or if there is a better suggestion for drilling technique...
    ms
    Matt Stemple
    Waterboro Maine
    1,020
    Default
    sorry no template
    I just drew the grid on the board then used a drillpress took about 1 1/2 - 2 hrs
    http://www.putfile.com/pic.php?img=5642036
    http://www.putfile.com/pic.php?img=5642039
    this was posted http://www.doityourselfchristmas.com...opic.php?t=151
    Mooresville, NC
    7,679
    Default Re: Spacing Template / Drill technique?
    Quote Originally Posted by stempile
    ms
    I just drew this up, maybe it will help. Just be sure when printing that it doesn't get scaled. It is a .750" grid. Just print as many as you need and tape them together. If you have access to a plotter, I can make the grid as large as you want to make it on a single sheet.
    8)
    Attached Files Attached Files
    48
    ms
    you might want to read the holes post I made.... it describes a method that I feel could fit your needs....
