Depends on the distance to the viewer. I'll let the experienced Panel Builders comment, but 1/2 or 1 inch seems to be common.
I am going with 15mm (25.4mm to the inch), so that the panel fits in nicely on the front of the house.
John.
What is the optimun spacing for the leds?
DocTanner
John.
[B]John[/B]
[url]www.xmasinmelb.com[/url] General Site
[url]www.xmasinmelb.com/zencart/[/url] Online Store
[SIGPIC][/SIGPIC]
We user a simple half sheet of Peg board and it works fine. We can read the sign, at night, from 2 ft away to over a block away.
My sig is better than yours!
Zane,Originally Posted by Zane
is that 25.4mm pegboard or that other type - the 1 inch pegboard..
Yes it is the 1 inch peg board.
Originally Posted by wjohn
I wish I could draw the little smily guy on his head so you didn't have to look at him upside down John...
jeff
Anyone have a good source for the led holders?
Thanks, DocTanner
Doc,
That is a GREAT sig.
I got a sheet of the 1" peg board. Found that the leads on the LEDs from Hong Kong are to short to connect without wire.
Not sure if I am going to drill closer holes or just start wire wrapping.
Also wondering about the focus. Seems to avoid bright spots all LEDs need to be angled the same way. Looks like it is difficult to do with the pre-drilled wood since the whole are just slightly to large for the 5mm LEDs.
ms
Matt Stemple
Matt,
1/2 spacing allows you to use the LED legs and just bend them in tohe direction required.
I am going with 15mm (2/3) inch for the same reason.
John.
[B]John[/B]
[SIGPIC][/SIGPIC]
