Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Looking to do a mobile lighting system.
    5,344
    Default Re: Looking to do a mobile lighting system.
    Battery life on the netbook may be an issue for a 5-hour show. Depends on the netbook model and configuration, of course.
    Nov 2008
    Clermont Florida
    753
    Very true... Sittinguphigh, how long of a sequence are you looking for? You might be able to get rid of the computer entirely, unless you wanted a long, complex sequence.
    Washington, Georgia
    3,271
    My Uncle's HP netbook can last for 8 Hrs with light gaming and I doubt it's configured for battery life.
    DIYC Links:
    [URL="http://doityourselfchristmas.com/wiki/index.php"]Christmas Wiki[/URL] | [URL="http://doityourselfchristmas.com/forums/addonchat.php"]Chat[/URL]
    Ricky, Jrd
    [COLOR="SeaGreen"]2012
    Fm-02 + Wall Wart Tamer
    2 Simple Renard 32
    15 SSROZ
    <a href="#" onclick="return(showhide(this));">Click here to show/hide my past display details ...</a>
    <script language="javascript">function showhide(anc){ //
    // traverse forward from anchor to find hidable div:
    for(; ; ){ if(!anc.nextSibling) break; if(anc.nextSibling.nodeName == "DIV") break; anc = anc.nextSibling; }//
    var Y='block', N='none', det=anc.nextSibling; //
    //fall-back plan: use named div:
    if (!det) det=document.getElementById('details'); //
    //toggle visibility:
    det.style.display=(det.style.display!=N)?N:Y; //
    //prevent page refresh:
    return false;}</script><div id="details" style="display:none;">2011
    Renard 24 v3.3 100%
    FM-02 with antenna 100%
    16' 8 channel Multi-color + Clear Megatree 100%</div>[/COLOR]
    10,283
    Quote Originally Posted by Jrd View Post
    I'm guessing once wireless/bluetooth and display is disabled/turned down/off, you should get 5 hours out of it.
    [/SIZE]
    [/COLOR][/I]
    Aug 2010
    12
    Last year I put together a battery 26 amps, intvertor MR Christmas inside lights to sounds controller and LCD lights. 6 channels Average watts per hours was 7 to 9 watts. About 35 hours of function. I have lots to play with. Trying to upgrade. But don't understand a lot of this stuff. Never put any PCB together.
    Speakers haven't got that far. MP3, FM transmitter with portable stereo, standalone speakers not really sure.
    Most netbbooks don't have the right program and screen and space. The one that can work aren't cost effective. At least I haven't found any yet.
    How much is a stand alone Helix?
    Would like to go with DC safer.
    Thanks for all the help people
    Washington, Georgia
    3,271
    SITTINGUPHIGH do you have a netbook or are you looking for suggestions?
    DIYC Links:
    Ricky, Jrd
    2 Simple Renard 32
    15 SSROZ
    Renard 24 v3.3 100%
    Canton, Ohio
    39
    An FM transmitter isn't really going to be of value, because the spectators won't have the time to tune to your show. You are going to have to budget for speakers and amplifier.
    10,283
    The Helix is AC powered so you would probably be looking at using an inverter to run it. I'm not sure I would suggest it as a first-timer's controller either as it requires other bits and pieces to configure it and load the shows, etc. Not knocking it - but I think other options would be better in your case. The other issue is which lights you plan to use. Keep in mind that most light strings, even LED, are all AC powered. You'll want to look at some of the color ribbons/strips available - many run off of 12v. A netbook with a DMX dongle and one of RPMs DC controllers or SSRs would be a good way to go I think. All of that could be used for your own home show as well later on.
    [/SIZE]
    [/COLOR][/I]
    San Antonio, TX
    150
    Just brainstorming here, but have you considered splitting the control part from the display part? Equestrian units in a parade often have a horse-drawn carriage or wagon in the group. This could be the platform for the sound system and Vixen notebook, while a Renard Wireless (Ren-W) radio link synchronizes the music to the LEDs on the horses. Each horse would have a receiver, battery pack, and DC controller for the lights it was wearing. The Ren-W system is flexible enough that all horses could have the same light display or each one could be a separate group of channels.
    (yet another Don) in pursuit of the perfect blinky.
    Aug 2010
    12
    Ren-wireless would be a good idea. But it's only for my horse.
    Using a DMX DC controller and maybe be DMX dongle recorder and reader.
    But what about the music.
    Netbook sure if you know a good one thats not to pricey.
