Results 1 to 10 of 37
Thread: DC SSR only working at half
    Scotland, UK
    389
    Thumbs down DC SSR only working at half
    Ive built some DC SSR's and connected them to my grinch controlled by a ren-c, i have both cables running between the ren-c and the grinch and both have a power supply. The lights are 12v led's and dim up and down fine however when I measured the voltage of the leds it was only 6v. Ive checked everything and cant seem to find any problem anywhere. Can anyone help?
    Thanks in advance Stephen
    Jun 2009
    Ottawa, Ontario, Canada
    2,799
    Default Re: DC SSR only working at half
    Quote Originally Posted by soakes94 View Post
    Where were you measuring?
    Did you try between +V and GND at the DCSSR itself?
    Standard Disclaimers apply:
    Scotland, UK
    389
    I measureed the voltage at the output, the input voltage for t led meausres 12v but the output is only 6v
    Oct 2008
    San Jose, CA
    8,819
    Remove the LED from the output and measure from the +DC to the output pin and verify if you are seeing 12v there or not with the channel on. Remember these are switched grounds. If that's OK then you know the SSR is working OK.
    Can you describe exactly how you have things wired up? Where is the current limiting resistor installed in the path and what do you see across that?
    I'm a little confused because you indicated it dimmed up and down fine?
    Brian
    Halloween in San Jose! - FB
    2014 Halloween Show - Homemade tombstones, Grave Crawler, 2x 3-axis skulls, 4x 1-axis skulls, Video Projection (more)
    2014 Christmas Show - 5x E681-12, 3x Ren48LSD, 32x42 TLS3001 pixel MT/Star, 4x Rainbow Floods, 12x DIYC Floods, SuperPixelStar, PixaBulb House outline
    Scotland, UK
    389
    Ive attached a picture of my DC SSR, the resistors between the opto and input are 680 ohm, the resistor on the 12v is a 10k ohm and the resistor between the opto and the mosfet is a 470 ohm. The 2 screw terminals read 12v, when I activate the channel to 100% im only getting about 6v out. I take this reading by keeping the positive end of the tester on the 12v screw terminal at the top and place the negative on the output screw terminal.
    Can anyone help?
    Jun 2009
    2,799
    What are you using to trigger the DCSSR? Any chance it's doing a PWM at about 50%? (Just looking to rule out the silly .. but sometimes overlooked solutions)
    How about a picture of the underside, so we can double check the circuit?
    Oct 2008
    San Jose, CA
    8,819
    It appears you etched your own boards - good for you! Can you list exactly which parts you used for the MOSFET and opto? Just wondering if the FET is not turning on completely or something...
    Brian
    Scotland, UK
    389
    Ive set it to 100% and my output is still 6v, Ive attached a picture of the bottom hope it helps
    Thanks for all your help
    Scotland, UK
    389
    Ive used 78L05 for my voltage reg, ive got 680ohm resistors between the opto and input, ive got a 10k ohm on the 12v into the mosfet, and a 470 ohm between the opto and mosfet and im using a RFD14N05L for the mosfet and also a 100nF cap.
    thanks stephen
    Oct 2008
    San Jose, CA
    8,819
    Good to hear - happy blinky-flashy!
    Brian
