Results 21 to 30 of 41
Thread: More than 250 Vixen sequences now available
    Jul 2009
    Kansas City, KS
    196
    Default Re: More than 250 Vixen sequences now available
    Quote Originally Posted by slicerd View Post
    Hi all I am getting a similar error to above for the "Michael Myers (Theme from Halloween)"
    If opening up the file in vixen v1 and saving it off to a different version works could somebody point me in the right directions.
    Hello,
    if that sequence works ok in Vixen 1.0, but causes those errors in Vixen 2.1, it might need to be converted to be used with Vixen 2.1.
    This thread here describes some good methods for converting Vixen 1.x sequences to Vixen 2.
    This is the method I use for conversion:
    1: Download the older Vixen 2.0, and extract. (Only the 2.0 release can convert up directly from 1.x. You should use 2.1+ again once converted).
    2: Copy the old v1 sequence into the newly extracted Vixen 2.0 'Sequences/' folder
    3: Run the Prepare.exe file located in the newly extracted Vixen 2.0 folder
    4: Done! The file should be converted for Vixen 2.x, and can now be copied into your Vixen 2.1 sequence folder for use
    If you have trouble converting it, you could post a link here if you want.
    Hope that helps,
    Mike.
    Ontario, Canada
    2,098
    oldcqr
    Is your database busted>?
    DB function failed with error number 145
    Table './oldcqr_db216519479/jos_session' is marked as crashed and should be repaired SQL=SELECT session_id FROM jos_session WHERE session_id = '9602a73dbe1340df4d6c7d244878e953'
    SQL =
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Tampa, FL
    1,420
    Possibly. One of my other clients complained about a problem with their mail yesterday and it was a crashed table. Let me look.....
    Edit: It sure was. Apparently my host had a problem with mySQL the other day and it went down mid-transaction. Looks like it hit them and me. Everything is fixed now. Thanks for the heads up!
    -Mike
    Ontario, Canada
    2,098
    Mike
    Thanks for the fast repair!
    Cheers!
    Steve
    My weather today
    9
    Thanks for this. As a newbie, I badly needed the sequences. I only am running 72 channels as of now.
    Nov 2017
    127
    Holy resurrected threads batman!! Last reply was over 7 years ago! You're better using the more modern sequences from the xlights google share.
    2,611
    "You're better using the more modern sequences from the xlights google share."
    DrewDennis, are they available in Vixen format (.vix), or do you know of a conversion routine?
    9,166
    Most of Mike's sequences were made back when even the first Vixen sequencer was fairly new and a show with 64 channels was considered "large." Back then, sequencing was a channel-by-channel, cell-by-cell activity -- there was none of this wild and woolly grouping, sub-grouping and object-oriented stuff. Pixels (at least those available for commercial purchase) hadn't been invented yet, and Vixen3 wasn't even in the back of anyone's mind. Xlights at that time (if it existed) was a basic, neophyte player, not a sequencer of any sort.
    So take these notes to heart when downloading Mike's sequences. A lot of them are very, very good, but if you're using one of the new sequencers, they may or may not even convert over without some tweaking. YMMV
    http://digwdf.com/store/
    Nov 2017
    127
    Vixen import the Fseq file and convert it, but I am not sure if it will with that old version of the file....but as dirknerkle said - if it works, you'll have a bunch of tweaking!
    2,611
    Quote Originally Posted by DrewDennis View Post
    I ask because I don't see an import in the Vixen software, anywhere. There is an "export", but no import that I can see.
