Results 1 to 8 of 8
Thread: Wiring the transformer to the Ren-T
    Default Wiring the transformer to the Ren-T
    Hi Again,
    So since I don't know for sure what I am doing, i wan tto be sure before i mess it up.
    i picked up thje radio shack transformer, there are two black wires comming out one side, and two black wires and a yellow wire comming out the other.
    Am i supposed to wire to the "T" points, or the "X" points. And which wires where?
    WOOT! Christmas!
    Powder Springs, GA
    1,028
    Default
    use the "X" points,... the "T" points are for testing,.....
    If you are not a supporting member please consider Becoming an Active Member
    Mooresville, NC
    5,059
    Default
    Quote Originally Posted by Mudsculpter
    The X pads are for the the Xion transformer and the T pads are for the Tamura transformer.
    But yes, the x pads are the ones to use for a CT transformer.
    The yellow wire is the CT
    Long Island, NY
    5,313
    Default
    CT = Center Tap
    Powder Springs, GA
    1,028
    Default
    Dang. I always thought they were test points
    Default
    Sounds easy enough, I think I can handle it!
    Thanks for the help!
    WOOT! Christmas!
    Jul 2007
    Houston, Texas
    123
    Default
    and is the recommendation to just drill a hole in the pcb to moun tthe transformer? Thanks.
    Long Island, NY
    5,313
    Default
    Quote Originally Posted by bonuts
    Yes. Be sure to drill mounting holes to secure the transformer to the pcb. If you do not and you drop the board, like I did then the transformer may pull away from the board either breaking the leads or pulling the leads out of the transformer. The latter happened to me.
