Thanks for the detailed response John and also for the wiki update.
you can use just a 0.1uF for C2, or 2 x 0.1 uF for C1/2 or most other options. The 78L05 is fairly stable, and the cap is there 'just to be sure'. If you dont have a 0.33uF, you can use a small electro as well, just make sure the operating voltage is OK for the DC supply (30 V for 24 VDC operating range).
This may well seem like a no-brainer to many, but electronics are not my speciality. Can I use the dcssr discussed in this thread and have it controlled by a renard ss16. I know the controller is ac and the ssr is dc?
If so where can I get the boards for the dcssr. If not can you point me in the direction that I need to go.
thanks in advance
bert-nc
An SS16 has all the electronics/triacs for running lights directly and you can't really use an SSR from a properly completed SS16. You need either a Ren64, a RenLV, or budude's Ren48LSD to run it. You could also use LabRat's simple Renard16. But any controller that has triacs built right onto it is not going to be a good choice for controlling a DC SSR, or an AC SSR for that matter.
dirknerkle
Just a disclaimer, that it isn't "my" simpleRen16... I just tweaked the layout to make it a bit more "home etch" friendly. The original files are in the "File Library" under Scorpia's Simple REN16
Standard Disclaimers apply:
Also - there is a "New and Improved" version they are working on which may do what you want as well - http://doityourselfchristmas.com/for...ead.php?t=7193
Go near the end of the thread for a description of the new version of the "Simple"...
Brian
Halloween in San Jose! - FB
I understand what you are saying. After reading your reply and I realize that will not work. However, what I think I need to know is if I can run my cable from computer to renard ss16, and then out from the ss16 to the dc ssr. so I would not be running the ssr from the renard ss 16, just allowing commands from the computer running vixen to pass thru the renard sss16 to the dcssr. Does that make sense:?: I am trying to run leds, and program them with the rest of the display, and renard ss16's is what I have.
bert-nc
No you can't.
Consider things this way. There are two major components to make the blinky work. The Controller.. and the SSR. The board you have now has both of them integrated into ONE BOARD. In order to make a DCSSR (or an ACSSR) work, you must have a controller that will turn it on/off.
So.. from your EXISTING REN16 you would run a cable (serial) to another controller (eg. The "SIMPLEREN16"). *THAT* controller would then have a cable that runs off to the individual SSR board(s) (upto 16 of them).
Did that help? Or just muddy the waters?
Bert,
the DCSSR does need a controller to tell it what to do.
The REN16SS or the REN16 are integrated controllers (aka they have a controller and SSR all on one board). While this makes it a simple board to deploy, it lock you into AC 110 V or something like that.
The DCSSR and SSRez were designed to work with any controller that did not have integrated SSRs. Examples of this are the GRINCH, REN64 and many others.
It was all about choice. individual SSRs (such as the DCSSR and the AC SSRez) let you mix and match on the same controller.
Hope that helps
