Results 1 to 10 of 11
Thread: Switching lights inside inflatable
    Jan 2010
    MA
    216
    Lightbulb Switching lights inside inflatable
    Hello , i want to be able to use the lights inside my inflatable as a channel, but an wondering how to do so, i want the blower to be plugged into the wall (so it stays inflated) and to switch the lights as i wish. I looked inside of it and was wondering if i could just cut the wire going from the base to the lights and then run that to my renard controller. My concern was that the four c7 bulbs would not be able to handle the power and burn out? has anyone done this and if so how?
    thanks in advance for all the good advice,
    chris
    10,284
    Default Re: Switching lights inside inflatable
    I know I've seen this done in other threads - you should be able to run the C7's on a separate circuit with no problems since they are usually just wired in parallel.
    Brian
    Christmas in San Jose! on Facebook
    Lithgow, NSW, Down Under
    885
    I actually removed the bulbs and placed a led portaflood in the base of all my blowups. Works well
    [url]http://www.lithgowlights.com/[/url]
    Jan 2010
    MA
    216
    okay sounds like it should work thanks all!!!
    Tampa, FL
    1,420
    I have a whole DIY article on exactly what you are trying to do:
    Electrical Modifications for Inflatables
    -Mike
    10,284
    Hmm - - I have a Snowman dad/son and a Mickey Mouse inflatable but haven't put them up for a couple years since the things don't go well with the dynamic nature of the other lights (at least IMO). Maybe I'll do this with mine as well so I can get them out of retirement...
    Brian
    Jul 2007
    Under the bed...
    551
    Quote Originally Posted by daviddth View Post
    Just be careful with the wattage of the lamp so you don't burn or melt the inflatable with lamp. But otherwise I really like this idea. I have a awesome 8' spider I use at halloween that this idea would be perfect for.
    Even Twitter has 140
    Washington, Georgia
    3,271
    I have an inflatable that won't light and the music doesn't play, maybe I will do this with it after checking it out closer when I get my DMM.
    DIYC Links:
    [URL="http://doityourselfchristmas.com/wiki/index.php"]Christmas Wiki[/URL] | [URL="http://doityourselfchristmas.com/forums/addonchat.php"]Chat[/URL]
    Ricky, Jrd
    [COLOR="SeaGreen"]2012
    Fm-02 + Wall Wart Tamer
    2 Simple Renard 32
    15 SSROZ
    <a href="#" onclick="return(showhide(this));">Click here to show/hide my past display details ...</a>
    <script language="javascript">function showhide(anc){ //
    // traverse forward from anchor to find hidable div:
    for(; ; ){ if(!anc.nextSibling) break; if(anc.nextSibling.nodeName == "DIV") break; anc = anc.nextSibling; }//
    var Y='block', N='none', det=anc.nextSibling; //
    //fall-back plan: use named div:
    if (!det) det=document.getElementById('details'); //
    //toggle visibility:
    det.style.display=(det.style.display!=N)?N:Y; //
    //prevent page refresh:
    return false;}</script><div id="details" style="display:none;">2011
    Renard 24 v3.3 100%
    FM-02 with antenna 100%
    16' 8 channel Multi-color + Clear Megatree 100%</div>[/COLOR]
    5
    I've been replacing my bulbs with Sun white led bulbs. Several have been rewired so they flash now. I just extended the light cord and ran it through the zipper. It worked very well for me. By the way through away the plastic covers the leds won't give off enough light with the cover still in place.
    Jan 2013
    Bristol, CT
    1,490
    I have my inflatable grinch and frosty only blow up on the song before theirs. I dont have the llights turn on until their song starts. People are always suprised when the look and see it suddenly appear.
