Results 41 to 48 of 48
Thread: Vixen and Windows 7
  1. #41
    Toronto,Ontario.Canada
    945
    Default Re: Vixen and Windows 7
    Thank-you Jrd...It will help avoid this issue with others...
    Yours always
    Joe...
    This is the year for my Mom.She passed away Feb 12 2012 and this year is dedicated to her and her memory.I will finally have it all finished and set to music all for her as I promised.Heres to you Mom (Dec 10,1944 - Feb 12,2012.I love you...
    Now on the web [URL="http://kraftchekchristmaslights.webs.com/"]http://kraftchekchristmaslights.webs.com/[/URL]
  2. #42
    Jun 2007
    Linton, Indiana
    78
    Just tried to run Vixen on my new laptop which is Windows 7 64bit and it keeps crashing with FMOD errors. Any idea how to fix?
    I'm sorry, but the application is about to die. Please take a screenshot of this message.
    An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
    at FMOD.Factory.FMOD_System_Create(IntPtr& system)
    at FMOD.Factory.System_Create(_System& system)
    at FMOD.fmod.CreateDeviceList()
    at FMOD.fmod.GetInstance(Int32 deviceIndex)
    at Vixen.MusicPlayer..ctor(Host host)
    at Vixen.Host..ctor(Form hostForm, Preference2 preferences)
    at Vixen.Form1..ctor(String[] args)
    at Vixen.Program.Main(String[] args)
    OK
  3. #43
    Apr 2009
    Denmak, 4700 Nęstved
    1,038
    Try to put vixen under C:/programs(x86)
    Quote Originally Posted by cgarwood View Post
    OK
    [I]Christmas - Light[/I]
    [COLOR="Red"]2011:[/COLOR]
    [FONT="Courier New"][SIZE="2"]6 x Renard 24 DC (My own design)[/SIZE][/FONT]
    [FONT="Courier New"][SIZE="2"]2 x Renard 24 V3.3[/SIZE][/FONT]
    [FONT="Courier New"][SIZE="2"]2 x Renard 48 LSD[/SIZE][/FONT]
    [FONT="Courier New"][SIZE="2"]1 x Renard 64[/SIZE][/FONT]
    [COLOR="Red"]100 % led lights[/COLOR]
    Thanks to all there is helping me ;)
    [URL="http://www.pcjulelys.dk"]http://www.pcjulelys.dk[/URL]
  4. #44
    Sep 2007
    Iowa
    457
    I believe the 64 bit/FMOD issue was resolved starting at version 2.1.
    http://www.doityourselfchristmas.com...ead.php?t=6174
    -Craig
  5. #45
    Sep 2009
    Waldorf, MD
    106
    Might I also suggest adding your windows user account to the permissions on the vixen folder and assigning full permissions. Windows 7 does add a layer of security that **might** cause issues for some users. Also, create a link to vixen.exe, right click on that shortcut, "Compatibility", Run in Windows XP SP3 mode, disable visual themes, disable desktop composition, disable display scaling on high DPI settings and Run this program as an administrator. On my install, this has created a very stable Vixen that has yet to error out in the 3 months of daily usage.
  6. #46
    Jan 2009
    Hanover PA
    476
    HI
    I think I have seen this, will check tonight.
    Try removing all Inputs/Ouputs/Addins see if it starts, then add back in only the dll's you need.
    I know I was having issues running the Analoge Frequency Addin on Windows 7, had to go to XP to get that sequence done.
    [B]Boucher Family Lights
    [URL="http://pachristmas.com"]http://pachristmas.com[/URL][/B]
  7. #47
    Jul 2009
    Mesa AZ
    130
    I am running Vixen 2.5 on Windows 7 Ultimate with no problems
  8. #48
    Apple Valley, MN
    3,752
    I am running Vixen 2.5.08 on Windows 7 64-bit Professional with no problems now. There were some problems getting it to run in C:/programs(x86). It appeared to be permission issues. I moved it to the root and it ran without changing anything. I created a Vixen directory on the root and then placed several versions in that directory. Everything from 2.1.1.0 on up runs without any issues.
    I tried a copy of Vixen 2.5.08 in the programs(x86) directory just to see what the error was and it seems to be working fine now. Maybe there was an update that fixed something. I got Windows 7 the day after it was released and there were a lot of updates initially.
    2.0.7 crashes with a permissions issue with the preferences file. I haven't pursued it but may, just to see if I can.
    [I]A mediocre person tells. A good person explains. A superior person demonstrates. A great person inspires others to see for themselves.[/I]
    <a href="#" onclick="return(showhide(this));">Click here to show/hide my display details ...</a>
    <script language="javascript">function showhide(anc){ for(; ; ){ if(!anc.nextSibling) break; if(anc.nextSibling.nodeName == "DIV") break; anc = anc.nextSibling; }//<br />
    var Y='block', N='none', det=anc.nextSibling; //<br />
    if (!det) det=document.getElementById('details'); det.style.display=(det.style.display!=N)?N:Y; return false;}</script><div id="details" style="display:none;"><br /><img src="http://www.vixenlights.com/sig/sig_h.php/128/All.gif" border="0" alt="" /></div><a href="#" onclick="return(showhide(this));">Click here to show/hide DIYC Links ...</a>
    if (!det) det=document.getElementById('details'); det.style.display=(det.style.display!=N)?N:Y; return false;}</script><div id="details" style="display:none;"><br /><b>Chat link</b> - <a href="http://doityourselfchristmas.com/forums/addonchat.php" target="_blank">http://doityourselfchristmas.com/forums/addonchat.php</a>
    <b>Christmas Wiki link</b> - <a href="http://doityourselfchristmas.com/wiki/index.php" target="_blank">http://doityourselfchristmas.com/wiki/index.php</a>
    <b>File Library link</b> - <a href="http://doityourselfchristmas.com/forums/dynamics/index.php" target="_blank">http://doityourselfchristmas.com/forums/dynamics/index.php</a>
    <b>Who's in chat?</b> - <a href="http://doityourselfchristmas.com/forums/chat/info.php" target="_blank">http://doityourselfchristmas.com/forums/chat/info.php</a>
    </div>
