Does anyone have a board design for a flood or strip that actually uses RGb 3 leg leds?
I have a few thousand of them and need a home for them.
Click here to show display details ...
Now a supporting member. I decided it was time to give something back to the forum that has helped me so much.
Then the Grinch thought of something he hadn't before. What if Christmas, he thought, doesn't come from a store. What if Christmas, perhaps, means a little bit more.
Can't say I've seen 3 leg RGB LEDs. Did you mean 4 leg? (one for each colour + a common)
The reason they don't get used is you can't configure them in a useful way. Using 3 resistors with each colour of each LED is grossly inefficient.
David...
Frank's strips use 4-pin Piranha RGB LEDs with individual resistors, as does many of the RGB pixel designs. As David said, for a panel, individual LEDs or 6-leaded RGB LEDs is a better choice since you can wire them in series (preferably with a true constant-current source) for more efficiency.
/mike
I've played with the common annode (or common cathode) LED's before, but most of them lack the brightness required to act as a flood lamp. They're great for a more subtle mood lamp (perhaps placed behind some type of translucent diffuser). But there's no way the ones I have would be able to flood anything more than a box of kleenex.
Your mileage may vary, may not appear as shown, I'm not a lawyer nor do I play one on television, these aren't the droids you seek.
Hi:
RGB floods.
Sounds like too much water in Russia.
Idun
Lotsa' Patience! (Some days you can't win, the others you lose, and forget about the rest)
Some mornings I wake up GRUMPY and other days I let her sleep!
Frank's strips hold up to 18 RGB SuperFlux/Piranha LEDs AND up to 18 single color (usually white but don't have to be) SuperFlux/Piranha LEDs. Each LED/color requires a current limiting resistor (18 x 4 or 52 resistors). The strips can use either common anode or cathode RGB LEDs but it's suggested you use common anode since most DC controllers here use switched grounds and common positive sources.
I was going to suggest the strip but - it would be a bit of work to install the regular RGB LEDs and as LabRat indicated, they typically aren't as bright. I got a bag of 50 of them myself a while back and still haven't figured out what to do with them...
Brian
Halloween in San Jose! - FB
Here ya go...
Frank's Super Strips
If you are interested, I have a bunch of these that I'm not going to use and will be offering up for sale. I also have some of the RGB and White LEDs to populate them.
Kelly
www.Kentucky-Christmas.com
Hi
Thanks. Not a lot of information on that page is ther but I know where to find it.
I was looking at those but decided from the picture of the board that it was for individual red, green and blue and white leds.
How much are the boards each? I would be interested in getting some/all.
I have plenty of RGB leds but could use a few whites if I did grab the boards.
Send me a PM if you like.
Cheers
D
