Results 1 to 9 of 9
Thread: Soldering station recommendations?
    Melbourne, Australia
    112
    Default Soldering station recommendations?
    hi everyone,
    i need to buy a soldering station. does anyone have any recommendations. i'd like it to be under $100.
    there are a few on ebay but i'm just not sure about quality etc.
    http://cgi.ebay.com.au/58W-Soldering...item53e09f4f5a
    the only thing that it would be used for is to solder together my christmas controllers, ssr's and portafloods.
    also, what solder would be best to use? what composition and diameter? what size tip is best to use?
    thanks, fj
    Jul 2008
    3,275
    Default Re: Soldering station recommendations?
    get the CSI-2A station from Circuit Specialists. You cannot go wrong with this.
    WLC Ventures is now [URL="http://radiant-holidays.com"]Radiant Holidays![/URL]
    Sep 2008
    Baulkham Hills, NSW
    2,608
    i would recommend this one http://cgi.ebay.com/ws/eBayISAPI.dll...m=360228202727
    It appears to be the same as the one g2ktcf has recommended.
    I notice the store is out of stock but message him as waited until the last lot came in.
    As for solder start with Tin/Lead (60%/40%) around the 0.8 to 1mm. The Flux is important, don't buy one with acid based flux. I usually buy "Multicore" brand solder but the stuff at Altronics is also OK.
    Tip size comes down to personal preference, 1.0 to 1.6mm chisels are excellent for most components. a 4mm flat is helpful for terminal blocks. You can do the TB if a 1.2mm tip as long as you increase the temp and move the iron around the pad a bit.
    I have the iron above with additional pencils with various tips already installed. that way I am not waiting for the iron to coll down before changing the tip.
    [B][I]Matt[/I][/B]
    1,177
    CSI -2A all the way. And buy three extra tips (conical, fine) now. You will need them after a couple dozen board builds.
    Whyalla, South Australia, Australia
    858
    i got the LK937 soldering station off ebay, an brought 2 extra tips.
    all i can say is it works great, the temp changed like instantly, when i change from circuit boards to soldering cable's together.
    best i ever found on ebay.
    ps. the LK is 'Lion King' brand.
    Over 50000ch last yr
    Oklahoma City, OK
    179
    I started soldering 2 months ago just for christmas stuff and I followed the recomendation of others here and bought the CSI-2A station. I can't imagine it working any better.
    112
    thanks for the recommendations.
    cheers, fj
    Dec 2008
    Pensacola, FL
    895
    Talking Re: Soldering station recommendations?
    Quote Originally Posted by smartalec View Post
    Are you sure it isn't "Little Known"??? :D :D :D
    Longfellow said that in this world a man must be either anvil or hammer.
    But some are neither, they are merely bellows.
    858
    Quote Originally Posted by WireWrap View Post
    i did'nt even know what it stood for until i read the box..
    it was a ebay buy, an now i can find it on ebay..lol
    but i did find a link to it. http://creatroninc.com/product.php?ProductID=155
    it works great, but after 3-4hr's the handle gets a little warm
