Results 1 to 10 of 16
Thread: How to take this plug apart?
    Dec 2008
    Keaau, HI
    220
    Default How to take this plug apart?
    I have a bunch of these plugs lying around, and need to make some terminators for my cheapy LED sets. I want to take this plug apart to install a resistor inside of it.
    1,177
    Default Re: How to take this plug apart?
    Why not install the resistor before the plastic plug on the wire?
    Orchard Park, New York
    290
    below is what I did. clip one wire shorter than the other, solder the resistor in, slip a piece of hear shrink tubing, heat, crimp the open end of the tubing while still hot to fuse the ends together, done.
    Ontario, Canada
    2,141
    I cannot tell for sure, but it appears there is an access area near that arrow on the plug, if I am correct there will be a very small fuse in there. you can use that spot for a resistor instead of the fuse.
    Inside that area you should be able to see the clips that hold the top female plate and wire terminals.
    CAREFULLY bend the tabs to release the top. You may snap them as they are not meant to be removed after initial installation.
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Oct 2009
    WhoVille
    313
    Yep , there is a little fuse access area , BUT , it does NOT get you to the other terminal so you can make a snubber . ( need to connect both sides , not one )
    As many mince pies as you taste at Christmas' so many happy months will you have . ( notice that this is NOT referring to fruit cakes - LOL )
    Dec 2008
    Keaau, HI
    220
    If I could open up this connector, what I can do is:
    1. Install the resistor in existing LED light strings.
    2. Remove the excess wire and install the resistor inside and use that as a snubber at the end of line on any string I choose.
    I only have 25 of those clipped ends, and didn't want to destroy one to see how it was assembled.
    Pomona, California
    1,078
    Quote Originally Posted by stanward View Post
    Use a big hammer?
    IMO, you would probably be better off soldering the resistor to the leads external to the plug, because if you mounted it inside it may melt the plastic or start a fire.
    Just my .02
    Robert
    Ontario, Canada
    2,141
    Ya know.. those little fuses look very SSR friendly.. too bad they are not 5Amps...
    Cheers!
    Steve
    My weather today
    Dec 2008
    Keaau, HI
    220
    I'm not sure how the resistors could start a fire, as they only will sink 0.3W when they are rated for 1W each. That is over a 3 times safety factor.
    Dec 2008
    Keaau, HI
    220
    Success!
    I was also able to take apart the female end as well.
    I think I will install the resistors on the female end on the existing LED light strings to give it a clean look.
